Problème de mise a jour plugin
Tc2112
Message par Tc2112 »
J'ai l'erreur suivante lors de la mise a jour du pluging zigbee (Plugin: 7.1.011 [5.260]):
"no changes added to commit (use "git add" and/or "git commit -a")"
Le log complet :
Starting Zigbee for Domoticz plugin Upgrade process.
PWD=/home/freebox/domoticz/plugins/Domoticz-Zigbee
HOME=/home/freebox/domoticz/plugins/Domoticz-Zigbee
LANG=C.UTF-8
INVOCATION_ID=139af2449bda41628aebac77e96483be
SHLVL=1
JOURNAL_STREAM=8:12313
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
_=/bin/env
uid=0(root) gid=0(root) groups=0(root)
root
PIP Options: --no-input install -r requirements.txt --ignore-requires-python --upgrade
Current version : {"branch": "stable7", "version": "7.1.011"}
latest git commit: 64952b7e69b2c1c69b6e4e2adcd9bfd6fa3727e1 Bump 7.1.011
(1) git config --global --add safe.directory
(2) updating Zigbee for Domoticz plugin
Setup submodule.recurse
hint: Pulling without specifying how to reconcile divergent branches is
hint: discouraged. You can squelch this message by running one of the following
hint: commands sometime before your next pull:
hint:
hint: git config pull.rebase false # merge (the default strategy)
hint: git config pull.rebase true # rebase
hint: git config pull.ff only # fast-forward only
hint:
hint: You can replace "git config" with "git config --global" to set a default
hint: preference for all repositories. You can also pass --rebase, --no-rebase,
hint: or --ff-only on the command line to override the configured default per
hint: invocation.
From https://github.com/zigbeefordomoticz/Domoticz-Zigbee
* [new branch] webui-rssi -> origin/webui-rssi
error: Your local changes to the following files would be overwritten by merge:
plugin.py
Please commit your changes or stash them before you merge.
Aborting
Updating 64952b7e..143b51cd
ERROR while running command 'git pull --recurse-submodules'.
Git Status: On branch stable7
Your branch is behind 'origin/stable7' by 314 commits, and can be fast-forwarded.
(use "git pull" to update your local branch)
Changes not staged for commit:
(use "git add ..." to update what will be committed)
(use "git restore ..." to discard changes in working directory)
modified: plugin.py
Untracked files:
(use "git add ..." to include in what will be committed)
.gitconfig
ReportsTransport-stats.json
Si quelqu'un peut m'aider
Ma config :
Version: 2024.4
Build Hash: 731719420
Compile Date: 2024-01-30 09:16:34
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
Re: Problème de mise a jour plugin
il est probable qu'il y ai eu des changements droits d'accès ...
peux-tu faire la manip suivante
cd Domoticz-Zigate
sudo Tools/big-clean-git.sh
puis re-essayer
git pull
et enfin
restart de domoticz
Tc2112
Bonjour Pipiche,
J'ai fait :
cd domoticz/plugins/Domoticz-Zigbee
et j'ai l'erreur :
command not found
Bibi49
Message par Bibi49 »
Test avec :
cd domoticz/plugins/Domoticz-Zigbee/Tools/
./big-clean-git.sh
RPI 2 -> Bullseye Lite
DomoticZ -> 2024.7
RFXCom 433E -> Pro1 1041
PiTInfo v1.4
USB->ùSD = Rpi-clones
Tc2112
Bonjour Bibi49,
J'ai testé, et j'ai le message d'erreur suivant :
-bash: ./big-clean-git.sh: Permission denied
Bibi49
avec le "sudo" ça devrait fonctionner.
sudo ./big-clean-git.sh
DomoticZ -> 2024.7
PiTInfo v1.4
Tc2112
La commande "sudo ./big-clean-git.sh" a l'air de fonctionner
j'ai ensuite fait :
git pull
fatal: .git/index: index file open failed: Permission denied (voir capture)
Bibi49
lorsque tu a "Permission denied", ajout "sudo" devant la ligne de commande :
sudo git pull
DomoticZ -> 2024.7
PiTInfo v1.4
Tc2112
Merci pour l'info, j'ai fait la commande :
sudo git pull
et jai eu l'erreur suivant (voir capture)
Bibi49
DomoticZ -> 2024.7
PiTInfo v1.4
