Plugin Z4D avec new matériel "passerelle Zigbee SLZB 06"
salinois
Re: Plugin Z4D avec new matériel "passerelle Zigbee SLZB 06"
Message par salinois »
ok
j'avais oublié les doubles cotes dans les modifs
il y a du mieux, sur la ligne Socket
mais encore qq erreurs
2025-01-27 15:19:34.469 Status: ZigbeeSLZB06: Z4D loads ZCL Cluster definitions
2025-01-27 15:19:34.490 Status: ZigbeeSLZB06: Z4D loaded 16 configuration from legacy database.
2025-01-27 15:19:34.490 Status: ZigbeeSLZB06: Z4D loads 16 configuration from the local certified Db.
2025-01-27 15:19:34.621 Error: ZigbeeSLZB06: JSON ConfFile: /usr/local/lib/python3.9/dist-packages/z4d_certified_devices/Certified/GammaTroniques/TICMeter-historique-tri-base.json load failed with error: JSONDecodeError, skipping this config file.
2025-01-27 15:19:34.647 Status: ZigbeeSLZB06: Z4D loads 614 Certified devices from repository.
2025-01-27 15:19:34.647 Status: ZigbeeSLZB06: Z4D loading database
2025-01-27 15:19:34.648 Status: ZigbeeSLZB06: Z4D loads 0 entries from /home/patrick/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-3.txt
2025-01-27 15:19:34.650 Status: ZigbeeSLZB06: Z4D configured to use transport mode: ZigpyZNP
2025-01-27 15:19:35.585 Status: ZigbeeSLZB06: Z4D starting ZNP
2025-01-27 15:19:35.588 Status: ZigbeeSLZB06: Z4D starts WebUI
2025-01-27 15:19:35.604 Status: ZigbeeSLZB06: WebUI thread started
2025-01-27 15:19:35.617 Status: ZigbeeSLZB06: WebUI Server started on 0.0.0.0:9440
2025-01-27 15:19:35.751 Status: ZigbeeSLZB06: Plugin looks to upgrade the Certified Device package
2025-01-27 15:19:38.068 Status: ZigbeeSLZB06: ++ Started radio znp port: socket://192.168.0.213:6638
2025-01-27 15:19:38.069 Status: ZigbeeSLZB06: ++ Use of Zigpy Persistent Db
2025-01-27 15:19:39.860 Status: ZigbeeSLZB06: ++ Forming a new network
2025-01-27 15:19:43.070 Status: ZigbeeSLZB06: Z4D Widgets usage is at 1.2% (252 units free)
2025-01-27 15:19:43.070 Status: ZigbeeSLZB06: Z4D started with legacy Framework
2025-01-27 15:20:40.159 Error: ZigbeeSLZB06: Error at startup Network formation refused: there is too much RF interference. Make sure your coordinator is on a USB 2.0 extension cable and away from any sources of interference, like USB 3.0 ports, SSDs, 2.4GHz routers, motherboards, etc.
2025-01-27 15:20:40.174 Status: ZigbeeSLZB06: ++ Network settings
2025-01-27 15:20:40.175 Status: ZigbeeSLZB06: ++ Device IEEE : ff:ff:ff:ff:ff:ff:ff:ff
2025-01-27 15:20:40.175 Status: ZigbeeSLZB06: ++ Device NWK : 0xFFFE
2025-01-27 15:20:40.177 Status: ZigbeeSLZB06: ++ Network Update Id : 0x0000
2025-01-27 15:20:40.178 Status: ZigbeeSLZB06: ++ PAN ID : 0xFFFE
2025-01-27 15:20:40.178 Status: ZigbeeSLZB06: ++ Extended PAN ID : ff:ff:ff:ff:ff:ff:ff:ff
2025-01-27 15:20:40.179 Status: ZigbeeSLZB06: ++ Channel : 0
2025-01-27 15:20:40.180 Error: ZigbeeSLZB06: start_zigpy_task error in radio_start:
2025-01-27 15:20:40.191 Error: ZigbeeSLZB06: Coordinator not correctly initialized
2025-01-27 15:20:52.062 Error: ZigbeeSLZB06: [ 70] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:21:02.086 Error: ZigbeeSLZB06: [ 80] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:21:12.060 Error: ZigbeeSLZB06: [ 90] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:21:22.083 Error: ZigbeeSLZB06: [100] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:21:32.057 Error: ZigbeeSLZB06: [110] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:21:42.081 Error: ZigbeeSLZB06: [120] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:21:43.084 ZigbeeSLZB06: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 3, 'name': 'ZigbeeSLZB06', 'address': '192.168.0.213', 'port': '6638', 'serialport': '/dev/serial1', 'Mode1': 'ZigpyZNP', 'Mode2': 'Socket', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:8080', 'Mode6': '0', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2025-01-27 15:21:43.086 Status: ZigbeeSLZB06: Plugin Restart command : http://127.0.0.1:8080/json.htm?type=com ... loglevel=7
2025-01-27 15:21:43.139 Status: ZigbeeSLZB06: Stop directive received.
2025-01-27 15:21:43.140 ZigbeeSLZB06: onStop()
2025-01-27 15:21:43.145 Error: ZigbeeSLZB06: Nothing reported as MacAddress is None!
2025-01-27 15:21:43.204 Error: ZigbeeSLZB06: Nothing reported as MacAddress is None!
2025-01-27 15:21:45.738 ZigbeeSLZB06: logging_thread - ended
2025-01-27 15:21:45.744 ZigbeeSLZB06: Logging Thread shutdown
2025-01-27 15:21:45.745 ZigbeeSLZB06: 'ZigpyForwarder_3' is running, it must be shutdown otherwise Domoticz will abort on plugin exit.
2025-01-27 15:21:45.749 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:46.749 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:47.749 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:48.776 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:49.777 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:50.777 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:51.778 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:52.778 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:53.784 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:54.785 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:55.786 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:55.787 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:21:55.787 ZigbeeSLZB06: Abandoning wait for Plugin thread shutdown, hang or crash may result.
salinois
ça a changé sur les widgets
Donc:
(1) la communication est maintenant établie
(2) c'est la bonne config
Le problème est que le plugin n'arrive pas à initialiser le réseau Zigbee. Du message, il indique trop d'interferences
- assures-toi d'être éloigné d'un Access Point Wifi
- assures-toi que le Wifi ne soit pas activé
(3) Peux-tu t'assurer d'activer le 'Initialize Coordinator' pour le premier RUN (après ne plus l'activer car il remet à zero le coordinateur)
Screenshot 2025-01-27 at 15.31.14.png (159.58 Kio) Consulté 3989 fois
salinois
wifi desactivé sur le Zigbee
salinois
passer en mode True
logs:
2025-01-27 15:36:31.503 Status: ZigbeeSLZB06: Started.
2025-01-27 15:36:32.392 Status: ZigbeeSLZB06: Initialized version 7.1, author 'pipiche38'
2025-01-27 15:36:32.393 Status: ZigbeeSLZB06: Welcome to Zigbee for Domoticz (Z4D) plugin.
2025-01-27 15:36:32.394 Status: ZigbeeSLZB06: PYTHONPATH is not set
2025-01-27 15:36:32.394 Status: ZigbeeSLZB06: Z4D requires python3.9 or above and you are running 3.9
2025-01-27 15:36:32.394 ZigbeeSLZB06: Z4D loading PluginConf
2025-01-27 15:36:32.396 ZigbeeSLZB06: Loading PluginConf - from Domoticz sqlite Db
2025-01-27 15:36:32.396 ZigbeeSLZB06: /home/patrick/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-03.json timestamp is 1737987495.0
2025-01-27 15:36:32.396 ZigbeeSLZB06: Dz PluginConf is older than Json Dz: 0 Json: 1737987495.0
2025-01-27 15:36:32.396 Error: ZigbeeSLZB06: Call to function 'onStart' failed, exception details:
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: Traceback (most recent call last):
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: File "/home/patrick/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1580, in onStart
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: _plugin.onStart()
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: File "/home/patrick/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 401, in onStart
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: self.pluginconf = PluginConf(
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: File "/home/patrick/domoticz/plugins/Domoticz-Zigbee/Classes/PluginConf.py", line 493, in __init__
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: _load_Settings(self)
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: File "/home/patrick/domoticz/plugins/Domoticz-Zigbee/Classes/PluginConf.py", line 572, in _load_Settings
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: _pluginConf = json.load(handle)
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: File "/usr/lib/python3.9/json/__init__.py", line 293, in load
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: return loads(fp.read(),
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: File "/usr/lib/python3.9/json/__init__.py", line 346, in loads
2025-01-27 15:36:32.399 Error: ZigbeeSLZB06: return _default_decoder.decode(s)
2025-01-27 15:36:32.400 Error: ZigbeeSLZB06: File "/usr/lib/python3.9/json/decoder.py", line 337, in decode
2025-01-27 15:36:32.400 Error: ZigbeeSLZB06: obj, end = self.raw_decode(s, idx=_w(s, 0).end())
2025-01-27 15:36:32.400 Error: ZigbeeSLZB06: File "/usr/lib/python3.9/json/decoder.py", line 353, in raw_decode
2025-01-27 15:36:32.400 Error: ZigbeeSLZB06: obj, end = self.scan_once(s, idx)
2025-01-27 15:36:32.400 Error: ZigbeeSLZB06: json.decoder.JSONDecodeError: Expecting ',' delimiter: line 16 column 3 (char 924)
2025-01-27 15:36:33.713 Error: WebServer:8080 thread seems to have ended unexpectedly (last update 894.000000 seconds ago)
et remis en false
2025-01-27 15:38:49.639 Status: ZigbeeSLZB06: Stop directive received.
2025-01-27 15:38:49.640 ZigbeeSLZB06: onStop()
2025-01-27 15:38:49.640 Error: ZigbeeSLZB06: Call to function 'onStop' failed, exception details:
2025-01-27 15:38:49.642 Error: ZigbeeSLZB06: Traceback (most recent call last):
2025-01-27 15:38:49.642 Error: ZigbeeSLZB06: File "/home/patrick/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1585, in onStop
2025-01-27 15:38:49.642 Error: ZigbeeSLZB06: _plugin.onStop()
2025-01-27 15:38:49.643 Error: ZigbeeSLZB06: File "/home/patrick/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 623, in onStop
2025-01-27 15:38:49.643 Error: ZigbeeSLZB06: WriteDeviceList(self, 0) # write immediatly
2025-01-27 15:38:49.643 Error: ZigbeeSLZB06: File "/home/patrick/domoticz/plugins/Domoticz-Zigbee/Modules/database.py", line 331, in WriteDeviceList
2025-01-27 15:38:49.643 Error: ZigbeeSLZB06: self.log.logging("Database", "Debug", "WriteDeviceList %s %s" %(self.HBcount, count))
2025-01-27 15:38:49.643 Error: ZigbeeSLZB06: AttributeError: 'NoneType' object has no attribute 'logging'
2025-01-27 15:38:49.765 Status: ZigbeeSLZB06: Exiting work loop.
2025-01-27 15:38:49.840 Status: ZigbeeSLZB06: Stopping threads.
2025-01-27 15:38:49.840 Status: ZigbeeSLZB06: Stopped.
2025-01-27 15:38:49.840 Status: ZigbeeSLZB06: Entering work loop.
2025-01-27 15:38:49.840 ZigbeeSLZB06: Worker thread started.
2025-01-27 15:38:49.840 Status: ZigbeeSLZB06: Started.
2025-01-27 15:38:50.653 Status: ZigbeeSLZB06: Initialized version 7.1, author 'pipiche38'
2025-01-27 15:38:50.655 Status: ZigbeeSLZB06: Welcome to Zigbee for Domoticz (Z4D) plugin.
2025-01-27 15:38:50.655 Status: ZigbeeSLZB06: PYTHONPATH is not set
2025-01-27 15:38:50.655 Status: ZigbeeSLZB06: Z4D requires python3.9 or above and you are running 3.9
2025-01-27 15:38:50.656 ZigbeeSLZB06: Z4D loading PluginConf
2025-01-27 15:38:50.657 ZigbeeSLZB06: Loading PluginConf - from Domoticz sqlite Db
2025-01-27 15:38:50.657 ZigbeeSLZB06: /home/patrick/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-03.json timestamp is 1737987495.0
2025-01-27 15:38:50.657 ZigbeeSLZB06: Dz PluginConf is older than Json Dz: 0 Json: 1737987495.0
2025-01-27 15:38:50.658 Error: ZigbeeSLZB06: Call to function 'onStart' failed, exception details:
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: Traceback (most recent call last):
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: File "/home/patrick/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1580, in onStart
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: _plugin.onStart()
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: File "/home/patrick/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 401, in onStart
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: self.pluginconf = PluginConf(
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: File "/home/patrick/domoticz/plugins/Domoticz-Zigbee/Classes/PluginConf.py", line 493, in __init__
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: _load_Settings(self)
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: File "/home/patrick/domoticz/plugins/Domoticz-Zigbee/Classes/PluginConf.py", line 572, in _load_Settings
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: _pluginConf = json.load(handle)
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: File "/usr/lib/python3.9/json/__init__.py", line 293, in load
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: return loads(fp.read(),
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: File "/usr/lib/python3.9/json/__init__.py", line 346, in loads
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: return _default_decoder.decode(s)
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: File "/usr/lib/python3.9/json/decoder.py", line 337, in decode
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: obj, end = self.raw_decode(s, idx=_w(s, 0).end())
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: File "/usr/lib/python3.9/json/decoder.py", line 353, in raw_decode
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: obj, end = self.scan_once(s, idx)
2025-01-27 15:38:50.661 Error: ZigbeeSLZB06: json.decoder.JSONDecodeError: Expecting ',' delimiter: line 16 column 3 (char 924)
2025-01-27 15:38:53.741 Error: WebServer:8080 thread seems to have ended unexpectedly (last update 1034.000000 seconds ago)
on est d'accord, quand je passe de true a false , j'utilise la touche "modifié" et non pas "ajouté "
il y a des ^problèmes sur le fichier de config
salinois
j'ai restarté Domoticz
2025-01-27 15:42:42.402 Status: ZigbeeSLZB06: Z4D started with legacy Framework
2025-01-27 15:42:56.300 Status: ZigbeeSLZB06: ++ ZNP Radio register default Ep
2025-01-27 15:42:56.331 Status: ZigbeeSLZB06: ++ ZNP Radio register any additional/specific Ep
2025-01-27 15:43:33.999 Status: ZigbeeSLZB06: ++ Forming a new network with no backup
2025-01-27 15:43:39.333 Status: ZigbeeSLZB06: ++ ZNP Radio register default Ep
2025-01-27 15:43:39.364 Status: ZigbeeSLZB06: ++ ZNP Radio register any additional/specific Ep
2025-01-27 15:43:51.100 Error: ZigbeeSLZB06: [ 70] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:44:01.077 Error: ZigbeeSLZB06: [ 80] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:44:11.098 Error: ZigbeeSLZB06: [ 90] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:44:21.073 Error: ZigbeeSLZB06: [100] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:44:31.093 Error: ZigbeeSLZB06: [110] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:44:39.753 Status: ZigbeeSLZB06: ++ ZNP Radio register default Ep
2025-01-27 15:44:39.779 Status: ZigbeeSLZB06: ++ ZNP Radio register any additional/specific Ep
2025-01-27 15:44:40.042 Status: ZigbeeSLZB06: ++ ZNP Configuration {'device': {'path': 'socket://192.168.0.213:6638', 'baudrate': 115200, 'flow_control': None}, 'network': {'tc_link_key': 5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, 'channels': <Channels.CHANNEL_25|CHANNEL_20|CHANNEL_15|CHANNEL_11: 34637824>, 'tc_address': None, 'extended_pan_id': None, 'key_sequence_number': 0, 'pan_id': None, 'update_id': 0, 'channel': None, 'key': None}, 'znp_config': {'tx_power': 0, 'prefer_endpoint_1': True, 'connect_dtr_pin_states': [False, False, False], 'sync_request_timeout': 15, 'skip_bootloader': True, 'auto_reconnect_retry_delay': 5, 'async_response_timeout': 30, 'max_concurrent_requests': None, 'connect_rts_pin_states': [False, True, False], 'led_mode': <LEDMode.OFF: 0>}, 'ota': {'enabled': False, 'broadcast_enabled': True, 'providers': [Ledvance(url='https://api.update.ledvance.com/v1/zigbee/firmwares', manufacturer_ids=(4489, 4364)), Sonoff(url=None, manufacturer_ids=(4742,)), Inovelli(url=None, manufacturer_ids=(4655,)), ThirdReality(url=None, manufacturer_ids=(4659, 4877, 5127))], 'broadcast_interval': 14040.0, 'broadcast_initial_delay': 14040.0, 'disable_default_providers': [], 'extra_providers': []}, 'source_routing': False, 'topology_scan_enabled': True, 'database_path': ':memory:', 'topology_scan_period': 720, 'backup_enabled': True, 'backup_period': 1, 'validate_network_settings': False, 'additional_endpoints': [], 'watchdog_enabled': True, 'max_concurrent_requests': 8, 'topology_scan_skip_coordinator': False}
2025-01-27 15:44:41.071 Error: ZigbeeSLZB06: [120] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-01-27 15:44:42.074 ZigbeeSLZB06: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 3, 'name': 'ZigbeeSLZB06', 'address': '192.168.0.213', 'port': '6638', 'serialport': '/dev/serial1', 'Mode1': 'ZigpyZNP', 'Mode2': 'Socket', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:8080', 'Mode6': '0', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2025-01-27 15:44:42.075 Status: ZigbeeSLZB06: Plugin Restart command : http://127.0.0.1:8080/json.htm?type=com ... loglevel=7
2025-01-27 15:44:42.113 Status: ZigbeeSLZB06: Stop directive received.
2025-01-27 15:44:42.114 ZigbeeSLZB06: onStop()
2025-01-27 15:44:42.118 Error: ZigbeeSLZB06: Nothing reported as MacAddress is None!
2025-01-27 15:44:42.180 Error: ZigbeeSLZB06: Nothing reported as MacAddress is None!
2025-01-27 15:44:59.788 Status: ZigbeeSLZB06: ++ ZNP Board Information
2025-01-27 15:44:59.789 Status: ZigbeeSLZB06: ++ Radio manufacturer : Texas Instruments
2025-01-27 15:44:59.790 Status: ZigbeeSLZB06: ++ Radio board model : CC2652
2025-01-27 15:44:59.791 Status: ZigbeeSLZB06: ++ Radio version : Z-Stack 20240710
2025-01-27 15:44:59.792 Status: ZigbeeSLZB06: ++ Network settings
2025-01-27 15:44:59.793 Status: ZigbeeSLZB06: ++ Device IEEE : 00:12:4b:00:31:dd:24:c5
2025-01-27 15:44:59.795 Status: ZigbeeSLZB06: ++ Device NWK : 0x0000
2025-01-27 15:44:59.795 Status: ZigbeeSLZB06: ++ Network Update Id : 0x0000
2025-01-27 15:44:59.796 Status: ZigbeeSLZB06: ++ PAN ID : 0x171E
2025-01-27 15:44:59.797 Status: ZigbeeSLZB06: ++ Extended PAN ID : 62:ef:33:a3:4e:10:49:b9
2025-01-27 15:44:59.797 Status: ZigbeeSLZB06: ++ Channel : 15
2025-01-27 15:45:19.823 Status: ZigbeeSLZB06: Coordinator backup is available: /home/patrick/domoticz/plugins/Domoticz-Zigbee/Data/Coordinator-03.backup
2025-01-27 15:45:30.723 ZigbeeSLZB06: logging_thread - ended
2025-01-27 15:45:30.738 ZigbeeSLZB06: Logging Thread shutdown
2025-01-27 15:45:30.739 ZigbeeSLZB06: 'ZigpyForwarder_3' is running, it must be shutdown otherwise Domoticz will abort on plugin exit.
2025-01-27 15:45:30.740 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:31.741 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:32.742 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:33.742 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:34.743 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:35.744 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:36.745 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:37.746 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:38.746 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:39.747 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:40.748 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:40.749 ZigbeeSLZB06: Abandoning wait for Plugin thread shutdown, hang or crash may result.
2025-01-27 15:45:47.062 Error: WebServer:8080 thread seems to have ended unexpectedly (last update 69.000000 seconds ago)
et j'ai du mieux sur l'interface WEB du plugin, pas eu le temps de faire copie ecran que j'ai plus rien et je perds la communication du Socket avec le Zigbee !!!
a ce stade; n'utilises plus le flag initialise car c'est ok
peux-tu partager le fichier de logs du plugin
plugins/Domoticz-Zigbee/Logs/PluginLogs-03.log
salinois
yes
voilà le log
PluginZigbee_03_3.log
(452.36 Kio) Téléchargé 172 fois
