[Béta]Plugin Zigate USB + Wifi
Re: [Béta]Plugin Zigate USB
Bonsoir
Voici mes logs:
2017-11-18 23:11:56.555 XiaomiGateway: Using 192.168.1.6 for local IP address.
2017-11-18 23:11:56.646 EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2017-11-18 23:11:56.654 EventSystem: Started
Je suis windows et python 3.6 d'installe
Merci de votre aide
Voici mes logs:
Merci de votre aide
bonjour,
Je viens de recevoir ma Zigate et je veux tester mes capteur XIAOMI AQARA (temp/hum/pres) !
J'ai Domoticz sur Synology (installé via le SPK de http://www.jadahl.com), j'ai installé le plugin mais impossible à faire fonctionner !
quelqu'un d'autre tourne sur Synology ?
Voici mes log avec la version "master" :
2017-11-19 12:10:10.343 PluginSystem: Entering work loop.
2017-11-19 12:12:11.002 (zigate) Started.
2017-11-19 12:12:11.198 (zigate) Entering work loop.
2017-11-19 12:12:11.199 (zigate) Initialized version 1.0.2, author 'zaraki673'
2017-11-19 12:12:11.200 (zigate) onStart called
2017-11-19 12:12:11.200 (zigate) Debug log level set to: 'true'.
2017-11-19 12:12:11.201 (zigate) Protocol set to: 'None'.
2017-11-19 12:12:11.201 (zigate) Transport set to: 'Serial', '/dev/ttyUSB0', 115200.
2017-11-19 12:12:11.219 (zigate) Connect directive received, action initiated successfully.
2017-11-19 12:12:11.219 (zigate) Calling message handler 'onConnect'.
2017-11-19 12:12:11.219 (zigate) onConnect called
2017-11-19 12:12:11.219 (zigate) Connected successfully to: /dev/ttyUSB0
2017-11-19 12:12:11.219 (zigate) Sending 18 bytes of data:
2017-11-19 12:12:11.219 (zigate) 01 02 10 21 02 10 02 14 2d 02 10 02 10 02 18 02 10 03 .. .. ...!....-.........
2017-11-19 12:12:11.219 (zigate) Sending 12 bytes of data:
2017-11-19 12:12:11.219 (zigate) 01 02 10 23 02 10 02 11 22 02 10 03 .. .. .. .. .. .. .. .. ...#...."...
2017-11-19 12:12:11.296 (zigate) Sending 10 bytes of data:
2017-11-19 12:12:11.296 (zigate) 01 02 10 24 02 10 02 10 24 03 .. .. .. .. .. .. .. .. .. .. ...$....$.
2017-11-19 12:12:11.372 (zigate) Sending 15 bytes of data:
2017-11-19 12:12:11.372 (zigate) 01 02 10 49 02 10 02 14 b0 ff fc e1 02 10 03 .. .. .. .. .. ...I....����...
2017-11-19 12:12:11.448 (zigate) Received 19 bytes of data:
2017-11-19 12:12:11.448 (zigate) 01 80 02 10 02 10 02 15 a4 02 10 02 10 02 10 21 02 10 03 .. .�......�......!...
2017-11-19 12:12:11.448 (zigate) 01 80 02 10 02 10 02 15 a6 02 10 02 10 02 10 23 02 10 03 .. .�......�......#...
2017-11-19 12:12:11.449 (zigate) 01 80 02 10 02 10 02 15 a1 02 10 02 10 02 10 24 02 10 03 .. .�......�......$...
2017-11-19 12:12:11.449 (zigate) Calling message handler 'onMessage'.
2017-11-19 12:12:11.449 (zigate) onMessage called
2017-11-19 12:12:11.489 (zigate) Calling message handler 'onMessage'.
2017-11-19 12:12:11.489 (zigate) onMessage called
2017-11-19 12:12:11.491 (zigate) Calling message handler 'onMessage'.
2017-11-19 12:12:11.491 (zigate) onMessage called
2017-11-19 12:12:20.723 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 12:12:30.772 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 12:12:40.810 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 12:12:50.801 (zigate) Calling message handler 'onHeartbeat'.
Après mise a jour de domoticz c'est ok ça fonctionne pour moi.
voila mon pb :
2017-11-19 17:25:52.933 (zigate) Started.
2017-11-19 17:25:52.934 EventSystem: reset all events...
2017-11-19 17:25:52.934 EventSystem: reset all device statuses...
2017-11-19 17:25:53.084 Python EventSystem: Initalizing event module.
2017-11-19 17:25:53.085 EventSystem: Started
2017-11-19 17:25:53.085 EventSystem: Queue thread started...
2017-11-19 17:25:53.323 PluginSystem: Entering work loop.
2017-11-19 17:25:53.577 (zigate) Initialized version 1.0.2, author 'zaraki673'
2017-11-19 17:25:53.580 (zigate) onStart called
2017-11-19 17:25:53.580 (zigate) Debug log level set to: 'true'.
2017-11-19 17:25:53.582 (zigate) Entering work loop.
2017-11-19 17:25:53.623 (zigate) Protocol set to: 'None'.
2017-11-19 17:25:53.623 (zigate) Transport set to: 'Serial', '', 115200.
2017-11-19 17:25:53.623 (zigate) Connect directive received, action initiation failed.
2017-11-19 17:25:53.624 (zigate) Calling message handler 'onConnect'.
2017-11-19 17:25:53.624 (zigate) onConnect called
2017-11-19 17:25:53.624 (zigate) Failed to connect (-1) to:
2017-11-19 17:25:53.624 (zigate) Failed to connect (-1) to: with error: open: No such file or directory
2017-11-19 17:26:03.155 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 17:26:03.155 (zigate) Transport set to: 'Serial', '', 115200.
2017-11-19 17:26:03.156 (zigate) Connect directive received, action initiation failed.
2017-11-19 17:26:03.156 (zigate) Calling message handler 'onConnect'.
2017-11-19 17:26:03.156 (zigate) onConnect called
ebretteville
- Contact :
À mon avis :
Il faut tous ce mettre sur la meme version que zak :
Domoticz v ? Stable ou beta ? Linux, Windows ou Synology ? Version de python ?
Ensuite ce forum n'est pas le bon endroit, il a donner son github c'est l'endroit où il travail, il est logique que ce soit la bas que les problèmes soient remontés, et que chacun y donne les bonnes infos :
Version de domoticz
Version de python
Version de Linux ou Windows
Version du plugin
Enfin les problèmes de comment j'installe python sous windows / Linux complètement hors sujet de la zigate : n'ont rien à faire dans ce topic car ce sont des soucis généraux.
Version de domoticz
Version de python
Version du plugin
https://github.com/sasu-drooz/Domoticz-Zigate/issues/7
Domoticz 3.8701 avec Python 3.5.1 sur Synology en DSM 6.1
Avec la version dev j'ai réussi à synchroniser 3 capteur Xiomi Aqara (temp./Hum./Pres.)
Mais les infos remontant ne passent pas tout le temps, et cette erreur revient souvent ( erreur sur les lignes 70 et 107 )
voila un extrait de mon log :
2017-11-19 20:26:43.146 (zigate) Calling message handler 'onMessage'.
2017-11-19 20:26:43.146 (zigate) onMessage called
2017-11-19 20:26:43.147 (zigate) ZigateDecode - decodind data : 018102120210021e1e9fc87202110214021302101402102802100211ff7203018102120210021f1b9fc8720211021402130210100210290210021226db7203
2017-11-19 20:26:43.147 (zigate) ZigateRead - decoded data : 018102000e1e9fc872010403001400280001ff7203018102000f1b9fc87201040300100029000226db7203
2017-11-19 20:26:43.148 (zigate) ZigateRead - Message Type : 8102, Data : 9fc872010403001400280001ff7203018102000f1b9fc87201040300100029000226db, RSSI : 72, Length : 000e, Checksum : 1e
2017-11-19 20:26:43.148 (zigate) ZigateRead - MsgType 8102 - reception data : 018102000e1e9fc872010403001400280001ff7203018102000f1b9fc87201040300100029000226db7203 ClusterID : 0403 Attribut ID : 0014 Src Addr : c872 Scr Ep: 01
2017-11-19 20:26:43.149 Error: (zigate) 'onMessage' failed 'UnicodeEncodeError'.
2017-11-19 20:26:43.149 Error: (zigate) ----> Line 107 in /usr/local/domoticz/var/plugins/ZIGATE/plugin.py, function onMessage
2017-11-19 20:26:43.149 Error: (zigate) ----> Line 70 in /usr/local/domoticz/var/plugins/ZIGATE/plugin.py, function onMessage
2017-11-19 20:26:43.662 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:26:53.646 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:27:03.695 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:27:13.690 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:27:23.728 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:27:33.750 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:27:43.822 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:27:53.841 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:28:03.878 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:28:13.863 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:28:23.894 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:28:33.938 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:28:43.972 (zigate) Calling message handler 'onHeartbeat'.
2017-11-19 20:28:54.008 (zigate) Calling message handler 'onMessage'.
2017-11-19 20:28:54.008 (zigate) onMessage called
J'ai réussi à installer sans problème ma Zigate, elle a l'air de démarrer correctement (en tout cas je n'ai pas de message d'erreur) en revanche pas moyen d'associer mes capteurs. J'ai essayé avec le module Aqara et le Xiaomi temperature mais ni l'un ni l'autre ne s'associent.
Je ne comprends peut-être pas bien comment faire mais grosso modo voilà ce que j'ai essayé : lors du démarrage du plugin j'appuie 5 secondes sur le bouton du dessus jusqu'à ce qu'une led bleue clignote. J'ai essayé également avant le démarrage voire après mais rien n'y fait sur les deux modules.
Vous avez une idée ?
Voici le log de ce que j'ai :
En tout cas merci pour le boulot sur le plugin !
Edit : j'ai réussi à faire fonctionner les capteurs et ça marche très bien. Par contre je les ai associés en utilisant l'outil Windows TestGUI de NXP en suivant la procédure indiquée sur le site zigate.fr.2017-11-22 10:11:59.679 (Zigate) Started.
2017-11-22 10:11:59.729 (Zigate) Initialized version 1.0.2, author 'zaraki673'
2017-11-22 10:11:59.730 (Zigate) onStart called
2017-11-22 10:11:59.730 (Zigate) Debug log level set to: 'true'.
2017-11-22 10:11:59.730 (Zigate) Protocol set to: 'None'.
2017-11-22 10:11:59.730 (Zigate) Transport set to: 'Serial', '/dev/ttyUSB-ZiGate', 115200.
2017-11-22 10:11:59.730 (Zigate) Entering work loop.
2017-11-22 10:11:59.774 (Zigate) Connect directive received, action initiated successfully.
2017-11-22 10:11:59.774 (Zigate) Calling message handler 'onConnect'.
2017-11-22 10:11:59.774 (Zigate) onConnect called
2017-11-22 10:11:59.774 (Zigate) Connected successfully to: /dev/ttyUSB-ZiGate
2017-11-22 10:11:59.774 (Zigate) Sending 18 bytes of data:
2017-11-22 10:11:59.774 (Zigate) 01 02 10 21 02 10 02 14 2d 02 10 02 10 02 18 02 10 03 .. .. ...!....-.........
2017-11-22 10:11:59.774 (Zigate) Sending 12 bytes of data:
2017-11-22 10:11:59.774 (Zigate) 01 02 10 23 02 10 02 11 22 02 10 03 .. .. .. .. .. .. .. .. ...#...."...
2017-11-22 10:11:59.774 (Zigate) Sending 10 bytes of data:
2017-11-22 10:11:59.774 (Zigate) 01 02 10 24 02 10 02 10 24 03 .. .. .. .. .. .. .. .. .. .. ...$....$.
2017-11-22 10:11:59.774 (Zigate) Sending 15 bytes of data:
2017-11-22 10:11:59.774 (Zigate) 01 02 10 49 02 10 02 14 b0 ff fc e1 02 10 03 .. .. .. .. .. ...I....����...
2017-11-22 10:11:59.874 (Zigate) Received 57 bytes of data:
2017-11-22 10:11:59.874 (Zigate) 01 80 02 10 02 10 02 15 a4 02 10 02 10 02 10 21 02 10 03 01 .�......�......!....
2017-11-22 10:11:59.874 (Zigate) 80 02 10 02 10 02 15 a6 02 10 02 10 02 10 23 02 10 03 01 80 �......�......#....�
2017-11-22 10:11:59.874 (Zigate) 02 10 02 10 02 15 a1 02 10 02 10 02 10 24 02 10 03 .. .. .. ......�......$...
2017-11-22 10:11:59.874 (Zigate) Calling message handler 'onMessage'.
2017-11-22 10:11:59.874 (Zigate) onMessage called
2017-11-22 10:12:09.282 (Zigate) Calling message handler 'onHeartbeat'.
2017-11-22 10:12:19.250 (Zigate) Calling message handler 'onHeartbeat'.
2017-11-22 10:12:29.268 (Zigate) Calling message handler 'onHeartbeat'.
2017-11-22 10:12:39.287 (Zigate) Calling message handler 'onHeartbeat'.
2017-11-22 10:12:49.302 (Zigate) Calling message handler 'onHeartbeat'.
Gateway reçu aujourd'hui, monté testée nickel, le plugin : nickel pour un debut, comment t'aider ?
On peut déja ajouter 3 appareils de marque Salus compatible Zigate (Une prise commandée, Un capteur d'ouverture de porte, une tete de robinet de radiateur)
Plugin mis à jour en branche principal en version 1.0.3
la liste des maj :
@Deennoo, je vais regarder pour faire une plugin de test pour la version wifi, je te tiens au courant
la liste des maj :
- -MsgType004d device annouce …
-Transcodage + checksum …
-Add domoticz.debug
-Calcul checksum OK
-Maj Zigateconf
-Suppression du fichier debug …
-Interroge le capteur nouvellement associer sur ces EP …
-Desactivation interrogation capteur par EP
-Fix issue 4 …
-Ajout detection type device (xiaomi) …
-Maj capteur lumi.weather et lumi.sensor.ht
-Fix Maj battery LVL
-Fix detecteur ouverture/fermeture et capteur de presence …
-Ajout support interrupteur (v1 et v2)
-Amélioration découpage a la réception …
- - Détecteur de présence Xiaomi(v1)
- Détecteur ouverture/fermeture Xiaomi(v1 et v2)
- Sonde Temp/Hum/Baro Xiaomi
- Sonde Temp/Hum Xiaomi
- - Regroupement des données sur un capteur (temp/hum et temp/hum/baro)
- Arrondi a 1 chiffre après la virgule des données de température/humidité et barométrie
