Tu va le mettre sur le GitHub ? Je suis en train de faire un article pour un blog info et j'envoi l'article vers ton Github pour récupérer le script. Merci
auteur : papoo
creation : 17/02/2019
mise à jour : 03/04/2019
https://pon.fr/dzvents-supervision-dun-nas-synology-avec-snmp/
https://github.com/papo-o/domoticz_scripts/blob/master/dzVents/scripts/synology2.lua
https://easydomoticz.com/forum/viewtopic.php?f=17&t=7022
https://www.domoticz.com/forum/viewtopic.php?f=59&t=24618
For this script to work you need to enable SNMP on your synology NAS and install SNMP on your Raspberry Pi
Enable SNMP on your synology NAS
Go toMain Menu>Control Panel >SNMP to enable SNMP service, which allows users to monitor
Synology DiskStation network flow with the network management software.
You can use V1/V2
And set a password (Community)
Install SNMP on Raspberry Pi
Log in to you Raspberry Pi and issue:
sudo apt-get install snmpd
Reboot your Pi:
sudo reboot
Check if SNMP is up and running, issue:
snmpget -v 2c -c PASSWORD -O qv NASIPADDRESS 1.3.6.1.4.1.6574.1.5.1.0
Replace PASSWORD with the Community name you entered while setting up your NAS
Replace NASIPADDRESS with the ip address of your NAS
You should get something like this:
"DS218+" which corresponds to your Synology Model
how to choose disk capacity to monitor?
snmpwalk -v 2c -c PASSWORD NASIPADDRESS 1.3.6.1.2.1.25.2.3.1.3
results of my DS218 :
HOST-RESOURCES-MIB::hrStorageDescr.1 = STRING: Physical memory
HOST-RESOURCES-MIB::hrStorageDescr.3 = STRING: Virtual memory
HOST-RESOURCES-MIB::hrStorageDescr.6 = STRING: Memory buffers
HOST-RESOURCES-MIB::hrStorageDescr.7 = STRING: Cached memory
HOST-RESOURCES-MIB::hrStorageDescr.8 = STRING: Shared memory
HOST-RESOURCES-MIB::hrStorageDescr.10 = STRING: Swap space
HOST-RESOURCES-MIB::hrStorageDescr.31 = STRING: /
HOST-RESOURCES-MIB::hrStorageDescr.36 = STRING: /tmp
HOST-RESOURCES-MIB::hrStorageDescr.37 = STRING: /run
HOST-RESOURCES-MIB::hrStorageDescr.38 = STRING: /dev/shm
HOST-RESOURCES-MIB::hrStorageDescr.39 = STRING: /sys/fs/cgroup
HOST-RESOURCES-MIB::hrStorageDescr.40 = STRING: /run/cgmanager/fs
HOST-RESOURCES-MIB::hrStorageDescr.51 = STRING: /volume1
HOST-RESOURCES-MIB::hrStorageDescr.54 = STRING: /volume1/@docker/btrfs
then modify OID_HDUnit, OID_HDTotal, OID_HDUsed variables with your last number choice (.38 on DSM 5.1, .41 on DSM 6.0+ or .51 on my new DS218)
if you have à DS2XX model, uncomment -- local OID_HDtemp2='1.3.6.1.4.1.6574.2.1.1.6.1' to show the hdd2 temperature
Then create:
1 device Switch
1 temperature device
3 percent devices
x meter device
-------------Fonctions----------------------
function format(str)
if (str) then
str = string.gsub (str, " Bytes", "")
str = string.gsub (str, " kB", "")
return str
-------------Fin Fonctions-----------------
local NasIp = "IP_Du_Nas" -- NAS IP Address
local CommunityPassword = "PASSWORD" -- SNMP Password
local NAS = "Synology" -- NAS Switch
local NAS_TEMP = "Synology Temp"
local NAS_CPU = "Synology Utilisation CPU" -- NAS CPU
local NAS_MEM = "Synology Utilisation RAM" -- NAS MEM
local NAS_HD_SPACE_PERC = "Synology Occupation Disque" -- NAS HD Space in %
local NAS_HD_SPACE = "Synology Espace Disponible" -- NAS HD Space in Go (custom sensor)
local NAS_HDD1_TEMP = "Synology HDD1 Temp" -- NAS HDD1 Temp
local NAS_HDD2_TEMP = "Synology HDD2 Temp" -- NAS HDD2 Temp
local NAS_HDD3_TEMP = "Synology HDD3 Temp" -- NAS HDD3 Temp
local NAS_HDD4_TEMP = "Synology HDD4 Temp" -- NAS HDD4 Temp
local OID_NAS_TEMP = '1.3.6.1.4.1.6574.1.2.0'
local OID_HDUnit = '1.3.6.1.2.1.25.2.3.1.4.51' -- OID HD Unit Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .51 on my DS218
local OID_HDTotal = '1.3.6.1.2.1.25.2.3.1.5.51' -- OID Total space volume in Go Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .51 on my DS218
local OID_HDUsed = '1.3.6.1.2.1.25.2.3.1.6.51' -- OID Space used volume in Go Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .51 on my DS218
local OID_CpuUser = '1.3.6.1.4.1.2021.11.9.0' -- OID CPU user
local OID_CpuSystem = '1.3.6.1.4.1.2021.11.10.0' -- OID CPU System
local OID_MemAvailable = '1.3.6.1.4.1.2021.4.13.0' -- OID Free Memory Available
local OID_HDtemp1 = '1.3.6.1.4.1.6574.2.1.1.6.0' -- OID Temperature HDD1
local OID_HDtemp2 = '1.3.6.1.4.1.6574.2.1.1.6.1' -- OID Temperature HDD2
local OID_HDtemp3 = '1.3.6.1.4.1.6574.2.1.1.6.2' -- OID Temperature HDD3
local OID_HDtemp4 = '1.3.6.1.4.1.6574.2.1.1.6.3' -- OID Temperature HDD4
local OID_Raid_Status = '1.3.6.1.4.1.6574.3.1.1.3.0' -- OID Raid Status
local OID_Physical_Memory_Units = '1.3.6.1.2.1.25.2.3.1.4.1'
local OID_Physical_Memory_Size = '1.3.6.1.2.1.25.2.3.1.5.1'
local OID_Physical_Memory_Used = '1.3.6.1.2.1.25.2.3.1.6.1'
local OID_system_memory_total = '1.3.6.1.4.1.2021.4.5.0'
local OID_system_memory_free = '1.3.6.1.4.1.2021.4.6.0'
local OID_system_vsmemory_shared = '1.3.6.1.4.1.2021.4.13.0'
local OID_system_vsmemory_buffer = '1.3.6.1.4.1.2021.4.14.0'
local OID_memTotalSwap = '1.3.6.1.4.1.2021.4.3.0'
local OID_memTotalReal = '1.3.6.1.4.1.2021.4.5.0'
local OID_memTotalFree = '1.3.6.1.4.1.2021.4.11.0'
return {
active = true,
on = {
timer = {'every minute'}
-- on = { devices = { "your trigger device" }},
logging = { -- level = domoticz.LOG_INFO, -- Seulement un niveau peut être actif; commenter les autres
-- level = domoticz.LOG_ERROR, -- Only one level can be active; comment others
level = domoticz.LOG_DEBUG,
-- level = domoticz.LOG_MODULE_EXEC_INFO,
marker = "Synology Monitor v1.3 " },
execute = function(dz)
local i = 0
local results = {}
local command = 'snmpget -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_NAS_TEMP..' '..OID_HDUnit..' '..OID_HDTotal..' '..OID_HDUsed..' '..OID_CpuUser..' '..OID_CpuSystem..' '..OID_MemAvailable..' '..OID_HDtemp1..' '..OID_HDtemp2 ..' '..OID_HDtemp3..' '..OID_HDtemp4..' '.. OID_memTotalSwap ..' '..OID_memTotalReal..' '..OID_memTotalFree--..' '..OID_Physical_Memory_Units ..' '..OID_Physical_Memory_Used..' '..OID_Physical_Memory_Size ..' '..OID_system_memory_total ..' '..OID_system_memory_free ..' '.. OID_system_vsmemory_shared ..' '.. OID_system_vsmemory_buffer
local handle = assert(io.popen(command))
for line in handle:lines() do
--for i, line in pairs(handle) do
--dz.log(format(line).." "..i,dz.LOG_info)
results[i] = format(line)
i = i + 1
handle:close()
if results[0] then
dz.log("NASTemp : "..results[0],dz.LOG_DEBUG)
if NAS_TEMP then dz.devices(NAS_TEMP).update(0,results[0]) end
if results[1] then dz.log("HDUnit : "..results[1],dz.LOG_DEBUG) end
if results[2] then dz.log("HDTotal : "..results[2],dz.LOG_DEBUG) end
if results[3] then dz.log("HDUsed : "..results[3],dz.LOG_DEBUG) end
if results[4] then dz.log("CpuUser : "..results[4],dz.LOG_DEBUG) end
if results[5] then dz.log("CpuSystem : "..results[5],dz.LOG_DEBUG) end
--if results[6] then dz.log("MemAvailable : "..results[6],dz.LOG_DEBUG) end
if results[7] then
dz.log("HDTemp1 : "..results[7],dz.LOG_DEBUG)
if NAS_HDD1_TEMP then dz.devices(NAS_HDD1_TEMP).update(0,results[7]) end
if results[8] then
dz.log("HDTemp2 : "..results[8],dz.LOG_DEBUG)
if NAS_HDD2_TEMP then dz.devices(NAS_HDD2_TEMP).update(0,results[8]) end
if results[9] then
dz.log("HDTemp3 : "..results[9],dz.LOG_DEBUG)
if NAS_HDD3_TEMP then dz.devices(NAS_HDD3_TEMP).update(0,results[9]) end
if results[10] then
dz.log("HDTemp4 : "..results[10],dz.LOG_DEBUG)
if NAS_HDD4_TEMP then dz.devices(NAS_HDD4_TEMP).update(0,results[10]) end
-- if results[11] then dz.log("Physical Memory Units : "..results[11],dz.LOG_DEBUG) end
-- if results[12] then dz.log("Physical Memory Used : "..results[12],dz.LOG_DEBUG) end
-- if results[13] then dz.log("Physical Memory Size : "..results[13],dz.LOG_DEBUG) end
if results[1] and results[2] then
--local HDFree = dz.utils.round(((results[2] - results[3]) * results[1] / 1024 / 1024 / 1024), 1)
HDTotalGo = dz.utils.round((results[2] * results[1] / 1024 / 1024 / 1024/1024),2)
dz.log("HDTotalGo : "..HDTotalGo,dz.LOG_DEBUG)
if results[1] and results[3] then
HDUsedGo = dz.utils.round(((results[3]) * results[1] / 1024 / 1024 / 1024/1024), 2)
--local HDUsedGo = (results[3] * results[1] / 1024 / 1024 / 1024)
--dz.log("HDUsedGo : "..HDUsedGo,dz.LOG_DEBUG)
if results[1] and results[2] and results[3] then
HDFreeGo = dz.utils.round(((results[2] - results[3]) * results[1] / 1024 / 1024 / 1024/1024),2)
--dz.log("HDFreeGo : "..HDFreeGo,dz.LOG_DEBUG)
if HDFreeGo then
dz.devices(NAS_HD_SPACE).update(0,HDFreeGo)
if results[2] and results[3] then
HDFreePerc = dz.utils.round(((results[3] * 100) / results[2]), 0)
if HDFreePerc then
dz.log("HDFreePercent : "..HDFreePerc,dz.LOG_DEBUG)
dz.devices(NAS_HD_SPACE_PERC).update(0,HDFreePerc)
if results[4] and results[5] then
CpuUsed = (results[4] + results[5])
if CpuUsed then
dz.log("CpuUsed : "..CpuUsed,dz.LOG_DEBUG)
dz.devices(NAS_CPU).update(0,CpuUsed)
-- if results[6] then
-- MemUsedPerc = dz.utils.round((((results[6] / 1024) *100 / 1024)), 0)
-- end
if results[11] then
dz.log("memTotalSwap: "..tostring(results[11]),dz.LOG_DEBUG)
if results[12] then
dz.log("memTotalReal: "..tostring(results[12]),dz.LOG_DEBUG)
if results[13] then
dz.log("memTotalFree: "..tostring(results[13]),dz.LOG_DEBUG)
-- dz.log("SysMemTotal: "..tostring(results[12]),dz.LOG_DEBUG)
-- end
-- dz.log("SysMemFree: "..tostring(results[13]),dz.LOG_DEBUG)
-- end
-- if results[14] then
-- dz.log("SysVsMemoryShared: "..tostring(results[14]),dz.LOG_DEBUG)
-- end
-- if results[15] then
-- dz.log("SysVsMemoryBuffer: "..tostring(results[15]),dz.LOG_DEBUG)
-- end
if results[11] and results[12] and results[13] then
--dz.log("MemoryPercentUsed: "..tostring(100-results[13]*100/(results[11]+results[12])),dz.LOG_DEBUG)
MemUsedPerc = dz.utils.round(100-results[13]*100/(results[11]+results[12]), 0)
if MemUsedPerc then
dz.log("MemUsedPercent : "..MemUsedPerc,dz.LOG_DEBUG)
dz.devices(NAS_MEM).update(0,MemUsedPerc)
-- if results[11] and results[13] then
-- MemTotal = dz.utils.round((((results[13] / results[11]) *100 / 1024)), 0)
-- end
-- if MemTotal then
-- dz.log("MemTotal : "..MemTotal,dz.LOG_DEBUG)
-- dz.devices(NAS_MEM).update(0,MemUsedPerc)
-- end
if results[0] and results[5] and results[6] then
dz.log("Requete SNMP correcte ",dz.LOG_DEBUG)
dz.devices(NAS).switchOn().checkFirst()
dz.log("Requete SNMP incorrecte ",dz.LOG_DEBUG)
dz.devices(NAS).switchOff().checkFirst()
--RAID Status :
--OK(1), Repairing(2), Migrating(3), Expanding(4), Deleting(5), Creating(6), RaidSyncing(7), RaidParityChecking(8), RaidAssembling(9), Canceling(10), Degraded(11), Creashed(12)
