[Tuto] Consomation d'eau ajout simple dans DomoticZ
jacques68
Re: [TUTO] Consomation d'eau ajout dans domoticz - SDEI
Message par jacques68 »
Merci je vais tester de suite!!! :D
jacques68
:oops: :oops: :oops:
Bon toujours pas mieux... toujours cette foutue erreur arithmetic.
J'ai donc repris mon fichier 2015-08.dat modifié manuellement pour voir ce que ca donne.
Ca bloque a l'etape 4.... J'ai ceci:
 - PART 4 Update the db
File size is NOT zero -> DB update needed
 Stoping Domoticz !
 Domoticz stopped
Update DB START
Update Values
Error: near line 1: attempt to write a readonly database
Error: near line 2: attempt to write a readonly database
Error: near line 3: attempt to write a readonly database
Error: near line 4: attempt to write a readonly database
Error: near line 5: attempt to write a readonly database
Error: near line 6: attempt to write a readonly database
Error: near line 7: attempt to write a readonly database
Update Status
Update DB END
 Starting Domoticz !
2015-08-11 20:03:46.034  Domoticz V2.2713 (c)2012-2015 GizMoCuz
2015-08-11 20:03:46.035  System: Raspberry Pi
2015-08-11 20:03:46.037  Startup Path: /home/pi/domoticz/
domoticz: Domoticz is starting up....
Je pense un probleme de droit en ecriture......mais ou?
EDIT: Bon ce soucis est réglé, probleme de droit sur le fichier DB mais le compteur est toujours a zero.....
jacques68
Requetes sql obtenues:
- PART 3 Generate SQL
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-01'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*18                                                         5), '468.902', '2015-08-01' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-02'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*34                                                         4), '469.246', '2015-08-02' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-03'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*44                                                         5), '469.691', '2015-08-03' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-04'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*58                                                         1), '470.271', '2015-08-04' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-05'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*43                                                         3), '470.704', '2015-08-05' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-06'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*50                                                         8), '471.212', '2015-08-06' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-07'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*41                                                         6), '471.628', '2015-08-07' );
update DeviceStatus set lastupdate = '2015-08-07 22:22:38' where id = 68;
sirus
Message par sirus »
Heu le saut de ligne entre 18 et 5 est pas normal. Tu es sur qu'il est bien en format unix?
Si tu veux utiliser ton fichier .dat il faut enlever le 100 * dans la requette. Le reste semble ok.
Si te veux juste tester le requete tu peux faire:
sqlite3 /home/pi/doloticz/doloticz.db
Puis tu tapes ta requeete sql...
Tu as aussi sqlite3browther que est plus convivial pour pc. Il te suffit juste a recupere ta db sur ton pc (voa sauvegarde par ex)... Ca te permetra de debuger tes requettes sql.
Raspberry B+ & PI2 / Domoticz / RFXtrx433E / multiple homemade devices
My blog/tutos for domoticz / electronics stuff : domotique.web2diz.net
jacques68
Re: [compteur d'eau ajout dans domoticz - SDEI
Bon après un reboot de tout le "tointoin"....j'obtiens ceci.... :)
root@raspberrypi:/home/pi# /home/pi/SDEI/updateConsoEau.sh
/home/pi/SDEI/updateConsoEau.sh[18]: [: argument expected
 - PART 1 Get the data from SDEI for 2015-08
 /home/pi/SDEI/2015-08.dat generated
rm: impossible de supprimer « /home/pi/SDEI/cookiefile »: Aucun fichier ou dossier de ce type
 - PART 2 Update .dat file
 /home/pi/SDEI/2015-08.dat Updated
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-01'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*185), '468.902', '2015-08-01' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-02'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*344), '469.246', '2015-08-02' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-03'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*445), '469.691', '2015-08-03' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-04'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*581), '470.271', '2015-08-04' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-05'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*433), '470.704', '2015-08-05' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-06'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*508), '471.212', '2015-08-06' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-07'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*416), '471.628', '2015-08-07' );
update DeviceStatus set lastupdate = '2015-08-07 00:02:20' where id = 69;
 Stoping Domoticz !
 Domoticz stopped
Update DB START
Update Values
Update Status
Update DB END
 Starting Domoticz !
2015-08-12 00:02:25.600  Domoticz V2.2713 (c)2012-2015 GizMoCuz
2015-08-12 00:02:25.601  System: Raspberry Pi
2015-08-12 00:02:25.602  Startup Path: /home/pi/domoticz/
 Domoticz started
 ### END ###
Ceci avec mon fichier modifié
Et dans Domoicz....
jacques68
:D :D On avance donc doucement mais surement....
Enfin j'espere... :mrgreen:
sirus
Message par sirus »
Cool !
Je pense que tu devrair yrnymter un update...
sudo apt-get update
sudo apt-get upgrade
jacques68
J'ai fait mise à jour comme demandé , mais en faisant tourné normalement toujours cette erreur aritmethic 0.185.
J'ai un peu bidouillé le code en ajoutant ceci:
sed -e 's/0./0/g' file3 > file4
Dans la partie : PART 2 set the file to be usable apres la ligne 76
Du coup mon 0.185 se transforme en 0185 et plus d'erreur arithmetic..... :mrgreen:
Mais se serait trop facile.....car dans mon fichier .dat au lieu d'obtenir ceci:
01/08/2015,185,468.902
02/08/2015,344,469.246
03/08/2015,445,469.691
04/08/2015,581,470.271
05/08/2015,433,470.704
06/08/2015,508,471.212
07/08/2015,416,471.628
J'obtiens cela:
[[0/0/205,0185,468.90],[0/0/205,0344,469.246],[0/0/205,0445,469.691],[0/0/205,0581,470271],[0/0/205,0433,47070],[0/0/205,050,471.212],[0/0/205,0416,471.628],[0/0/205,04,472.08],[0/0/205,0314,472.3$
Probleme de mise en forme sous forme de tableau....et la date déconne.... :?: :?: :?:
En fait faudrait que je puisse adapter ma formule juste sur la deuxieme colonne.....je cherche je cherche mais suis qu'un pauvre débutant alors pas évident...
sirus
Message par sirus »
oui en modifiant les sed tu devrais arriver a tes fins !
sed -e 's/\\//g' $export_file > file1  # supprime les "\" et les remplace par rien
sed -e 's/\],\[/\n/g' file1 > file2  # supprime les "],[" et  remplace par des saut de ligne
sed -e 's/\[\[/\n/g' file2 > file3  # supprime les "[["   et remplace par des saut de ligne
sed -e 's/\"//g' file3  |grep -v ",0,0" |grep -e '^$' -v |grep -v ERR  > $export_file
# supprime les " , les ",0,0"
# supprime les lignes d'erreur si il y en a (ex : pbl de connection)
pour t'aider tu peux supprimer la ligne :
rm file1 file2 file3
qui supprime les fichier intermédiaires
Pour travailler que sur val (premiere valeur du fichier apres mise ne format ) tu peux remplacer :
val1=$(( $val * 100))
par :
val1=`echo $val | sed -e 's/0\.//g'`
ca va pas marcher si tu consomme plus de 1m3... mais ce reste pas trop mal .. .
jacques68
Merci!!
Je lance mes test!!! :D
EDIT:
Bon pour l'instant rien de neuf...choux blanc toujours la meme erreur arthmetic......
Dans le fichier .dat il faut que j'arrive a supprimer "0." par "0" et après ca roulera mieux....
