Re: [Plugin] - Volet Velux IO-Homecontrol
Publié : 04 janv. 2021, 19:07
J'ai souvent des problèmes de connexion. Domoticz ne se connecte plus à connexoon.
Avez vous deja eu ça ?
voici mon log
voici mon log
2021-01-04 18:42:00.727 Status: Domoticz V2020.2 (c)2012-2020 GizMoCuz
2021-01-04 18:42:00.728 Status: Build Hash: b63341bc0, Date: 2020-04-26 13:47:55
2021-01-04 18:42:00.728 Status: Startup Path: /home/pi/domoticz/
2021-01-04 18:42:00.844 Status: PluginSystem: Started, Python version '3.7.3'.
2021-01-04 18:42:00.853 Status: WebServer(HTTP) started on address: :: with port 8080
2021-01-04 18:42:00.858 Status: WebServer(SSL) started on address: :: with port 443
2021-01-04 18:42:00.861 Status: TCPServer: shared server started...
2021-01-04 18:42:00.861 Status: RxQueue: queue worker started...
2021-01-04 18:42:02.862 Status: Darksky: Started...
2021-01-04 18:42:02.862 Status: (Connexoon) Started.
2021-01-04 18:42:02.863 Status: EventSystem: reset all events...
2021-01-04 18:42:02.864 Status: EventSystem: reset all device statuses...
2021-01-04 18:42:02.873 Status: NotificationSystem: thread started...
2021-01-04 18:42:03.009 Status: Python EventSystem: Initalizing event module.
2021-01-04 18:42:03.009 Status: EventSystem: Started
2021-01-04 18:42:03.010 Status: EventSystem: Queue thread started...
2021-01-04 18:42:03.251 Status: PluginSystem: Entering work loop.
2021-01-04 18:42:03.418 Status: (Connexoon) Entering work loop.
2021-01-04 18:42:03.418 Status: (Connexoon) Initialized version 2.0.2, author 'nonolk'
2021-01-04 18:42:03.421 Status: (Connexoon) Starting Tahoma blind plugin
2021-01-04 18:42:03.730 Status: (Connexoon) Tahoma auth succeed
2021-01-04 18:42:03.784 Status: (Connexoon) Tahoma listener registred
2021-01-04 18:42:03.784 Status: (Connexoon) Check setup status at statup
2021-01-04 18:42:03.863 Status: MQTT: Connecting to localhost:1883
2021-01-04 18:42:04.065 Status: MQTT: connected to: localhost:1883
2021-01-04 18:42:04.265 Status: MQTT: Subscribed
2021-01-04 18:42:08.934 Status: Incoming connection from: 192.168.1.101
2021-01-04 18:43:43.695 (Connexoon) 6f 76 65 72 6b 69 7a 0d 0a 53 74 72 69 63 74 2d 54 72 61 6e overkiz..Strict-Tran
2021-01-04 18:43:43.695 (Connexoon) 73 70 6f 72 74 2d 53 65 63 75 72 69 74 79 3a 20 6d 61 78 2d sport-Security:.max-
2021-01-04 18:43:43.695 (Connexoon) 61 67 65 3d 33 31 35 33 36 30 30 30 3b 20 69 6e 63 6c 75 64 age=31536000;.includ
2021-01-04 18:43:43.695 (Connexoon) 65 53 75 62 44 6f 6d 61 69 6e 73 0d 0a 43 6f 6e 74 65 6e 74 eSubDomains..Content
2021-01-04 18:43:43.695 (Connexoon) 2d 54 79 70 65 3a 20 61 70 70 6c 69 63 61 74 69 6f 6e 2f 6a -Type:.application/j
2021-01-04 18:43:43.695 (Connexoon) 73 6f 6e 3b 63 68 61 72 73 65 74 3d 55 54 46 2d 38 0d 0a 4b son;charset=UTF-8..K
2021-01-04 18:43:43.695 (Connexoon) 65 65 70 2d 41 6c 69 76 65 3a 20 74 69 6d 65 6f 75 74 3d 35 eep-Alive:.timeout=5
2021-01-04 18:43:43.695 (Connexoon) 2c 20 6d 61 78 3d 35 30 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e ,.max=50..Connection
2021-01-04 18:43:43.695 (Connexoon) 3a 20 4b 65 65 70 2d 41 6c 69 76 65 0d 0a 54 72 61 6e 73 66 :.Keep-Alive..Transf
2021-01-04 18:43:43.695 (Connexoon) 65 72 2d 45 6e 63 6f 64 69 6e 67 3a 20 63 68 75 6e 6b 65 64 er-Encoding:.chunked
2021-01-04 18:43:43.695 (Connexoon) 0d 0a 0d 0a 32 0d 0a 5b 5d 0d 0a .. .. .. .. .. .. .. .. .. ....2..[]..
2021-01-04 18:43:43.696 (Connexoon) Processing 'ReadEvent' message
2021-01-04 18:43:43.696 (Connexoon) Received 5 bytes of data
2021-01-04 18:43:43.696 (Connexoon) 30 0d 0a 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 0....
2021-01-04 18:43:43.696 (Connexoon) Pushing 'onMessageCallback' on to queue
2021-01-04 18:43:43.696 (Connexoon) Processing 'onMessageCallback' message
2021-01-04 18:43:43.696 (Connexoon) Calling message handler 'onMessage'.
2021-01-04 18:43:43.696 (Connexoon) []
2021-01-04 18:43:48.695 (Connexoon) Queued asynchronous secure read aborted.
2021-01-04 18:43:48.695 (Connexoon) Pushing 'DisconnectedEvent' on to queue
2021-01-04 18:43:48.707 (Connexoon) Processing 'DisconnectedEvent' message
2021-01-04 18:43:48.707 (Connexoon) Disconnect event received for 'tahomalink.com:443'.
2021-01-04 18:43:48.708 (Connexoon) Pushing 'onDisconnectCallback' on to queue
2021-01-04 18:43:48.708 (Connexoon) Processing 'onDisconnectCallback' message
2021-01-04 18:43:48.708 (Connexoon) Calling message handler 'onDisconnect'.
2021-01-04 18:43:53.447 (Connexoon) Pushing 'onHeartbeatCallback' on to queue
2021-01-04 18:43:53.468 (Connexoon) Processing 'onHeartbeatCallback' message
2021-01-04 18:43:53.468 (Connexoon) Calling message handler 'onHeartbeat'.
2021-01-04 18:43:53.468 (Connexoon) Pushing 'ConnectDirective' on to queue
2021-01-04 18:43:53.468 (Connexoon) Processing 'ConnectDirective' message
2021-01-04 18:43:53.468 (Connexoon) Transport set to: 'TCP/IP', tahomalink.com:443.
2021-01-04 18:43:53.502 (Connexoon) Connect directive received, action initiated successfully.
2021-01-04 18:43:53.779 (Connexoon) Pushing 'onConnectCallback' on to queue
2021-01-04 18:43:53.803 (Connexoon) Processing 'onConnectCallback' message
2021-01-04 18:43:53.803 (Connexoon) Calling message handler 'onConnect'.
2021-01-04 18:43:53.803 (Connexoon) Pushing 'WriteDirective' on to queue
2021-01-04 18:43:53.803 (Connexoon) Processing 'WriteDirective' message
2021-01-04 18:43:53.803 (Connexoon) Sending 449 bytes of data
2021-01-04 18:43:53.803 (Connexoon) 50 4f 53 54 20 2f 65 6e 64 75 73 65 72 2d 6d 6f 62 69 6c 65 POST./enduser-mobile
2021-01-04 18:43:53.803 (Connexoon) 2d 77 65 62 2f 65 6e 64 75 73 65 72 41 50 49 2f 65 76 65 6e -web/enduserAPI/even
2021-01-04 18:43:53.803 (Connexoon) 74 73 2f 63 65 37 64 64 63 65 39 2d 61 63 31 30 2d 33 65 30 ts/ce7ddce9-ac10-3e0
2021-01-04 18:43:53.803 (Connexoon) 31 2d 31 32 35 34 2d 31 36 39 61 39 34 31 63 64 37 66 62 2f 1-1254-169a941cd7fb/
2021-01-04 18:43:53.803 (Connexoon) 66 65 74 63 68 20 48 54 54 50 2f 31 2e 31 0d 0a 41 75 74 68 fetch.HTTP/1.1..Auth
2021-01-04 18:43:53.804 (Connexoon) 6f 72 69 7a 61 74 69 6f 6e 3a 20 42 61 73 69 63 20 5a 6e 4a orization:.Basic.ZnJ
2021-01-04 18:43:53.804 (Connexoon) 68 62 6d 4e 70 63 79 35 6a 62 32 35 78 64 57 56 7a 51 47 64 hbmNpcy5jb25xdWVzQGd
2021-01-04 18:43:53.804 (Connexoon) 74 59 57 6c 73 4c 6d 4e 76 62 54 70 6d 63 6d 46 75 59 32 6c tYWlsLmNvbTpmcmFuY2l
2021-01-04 18:43:53.804 (Connexoon) 7a 4d 44 63 3d 0d 0a 55 73 65 72 2d 41 67 65 6e 74 3a 20 44 zMDc=..User-Agent:.D
2021-01-04 18:43:53.804 (Connexoon) 6f 6d 6f 74 69 63 7a 2f 31 2e 30 0d 0a 48 6f 73 74 3a 20 74 omoticz/1.0..Host:.t
2021-01-04 18:43:53.804 (Connexoon) 61 68 6f 6d 61 6c 69 6e 6b 2e 63 6f 6d 0d 0a 43 6f 6e 6e 65 ahomalink.com..Conne
2021-01-04 18:43:53.804 (Connexoon) 63 74 69 6f 6e 3a 20 6b 65 65 70 2d 61 6c 69 76 65 0d 0a 41 ction:.keep-alive..A
2021-01-04 18:43:53.804 (Connexoon) 63 63 65 70 74 2d 45 6e 63 6f 64 69 6e 67 3a 20 67 7a 69 70 ccept-Encoding:.gzip
2021-01-04 18:43:53.804 (Connexoon) 2c 20 64 65 66 6c 61 74 65 0d 0a 41 63 63 65 70 74 3a 20 2a ,.deflate..Accept:.*
2021-01-04 18:43:53.804 (Connexoon) 2f 2a 0d 0a 43 6f 6e 74 65 6e 74 2d 54 79 70 65 3a 20 61 70 /*..Content-Type:.ap
2021-01-04 18:43:53.804 (Connexoon) 70 6c 69 63 61 74 69 6f 6e 2f 6a 73 6f 6e 0d 0a 43 6f 6f 6b plication/json..Cook
2021-01-04 18:43:53.805 (Connexoon) 69 65 3a 20 4a 53 45 53 53 49 4f 4e 49 44 3d 33 42 39 42 45 ie:.JSESSIONID=3B9BE
2021-01-04 18:43:53.805 (Connexoon) 34 33 45 42 32 32 36 41 39 37 32 35 33 42 35 42 38 44 35 43 43EB226A97253B5B8D5C
2021-01-04 18:43:53.805 (Connexoon) 30 34 46 35 41 41 43 3b 20 50 61 74 68 3d 2f 65 6e 64 75 73 04F5AAC;.Path=/endus
2021-01-04 18:43:53.805 (Connexoon) 65 72 2d 6d 6f 62 69 6c 65 2d 77 65 62 3b 20 53 65 63 75 72 er-mobile-web;.Secur
2021-01-04 18:43:53.805 (Connexoon) 65 3b 20 48 74 74 70 4f 6e 6c 79 3b 20 53 61 6d 65 53 69 74 e;.HttpOnly;.SameSit
2021-01-04 18:43:53.805 (Connexoon) 65 3d 4e 6f 6e 65 0d 0a 43 6f 6e 74 65 6e 74 2d 4c 65 6e 67 e=None..Content-Leng
2021-01-04 18:43:53.805 (Connexoon) 74 68 3a 20 30 0d 0a 0d 0a .. .. .. .. .. .. .. .. .. .. .. th:.0....
2021-01-04 18:43:53.861 (Connexoon) Pushing 'ReadEvent' on to queue
2021-01-04 18:43:53.905 (Connexoon) Processing 'ReadEvent' message
2021-01-04 18:43:53.906 (Connexoon) Received 271 bytes of data
2021-01-04 18:43:53.906 (Connexoon) 48 54 54 50 2f 31 2e 31 20 32 30 30 20 0d 0a 44 61 74 65 3a HTTP/1.1.200...Date:
2021-01-04 18:43:53.906 (Connexoon) 20 4d 6f 6e 2c 20 30 34 20 4a 61 6e 20 32 30 32 31 20 31 37 .Mon,.04.Jan.2021.17
2021-01-04 18:43:53.906 (Connexoon) 3a 34 33 3a 35 33 20 47 4d 54 0d 0a 53 65 72 76 65 72 3a 20 :43:53.GMT..Server:.
2021-01-04 18:43:53.906 (Connexoon) 6f 76 65 72 6b 69 7a 0d 0a 53 74 72 69 63 74 2d 54 72 61 6e overkiz..Strict-Tran
2021-01-04 18:43:53.906 (Connexoon) 73 70 6f 72 74 2d 53 65 63 75 72 69 74 79 3a 20 6d 61 78 2d sport-Security:.max-
2021-01-04 18:43:53.906 (Connexoon) 61 67 65 3d 33 31 35 33 36 30 30 30 3b 20 69 6e 63 6c 75 64 age=31536000;.includ
2021-01-04 18:43:53.906 (Connexoon) 65 53 75 62 44 6f 6d 61 69 6e 73 0d 0a 43 6f 6e 74 65 6e 74 eSubDomains..Content
2021-01-04 18:43:53.906 (Connexoon) 2d 54 79 70 65 3a 20 61 70 70 6c 69 63 61 74 69 6f 6e 2f 6a -Type:.application/j
2021-01-04 18:43:53.906 (Connexoon) 73 6f 6e 3b 63 68 61 72 73 65 74 3d 55 54 46 2d 38 0d 0a 4b son;charset=UTF-8..K
2021-01-04 18:43:53.906 (Connexoon) 65 65 70 2d 41 6c 69 76 65 3a 20 74 69 6d 65 6f 75 74 3d 35 eep-Alive:.timeout=5
2021-01-04 18:43:53.906 (Connexoon) 2c 20 6d 61 78 3d 35 30 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e ,.max=50..Connection
2021-01-04 18:43:53.906 (Connexoon) 3a 20 4b 65 65 70 2d 41 6c 69 76 65 0d 0a 54 72 61 6e 73 66 :.Keep-Alive..Transf
2021-01-04 18:43:53.906 (Connexoon) 65 72 2d 45 6e 63 6f 64 69 6e 67 3a 20 63 68 75 6e 6b 65 64 er-Encoding:.chunked
2021-01-04 18:43:53.906 (Connexoon) 0d 0a 0d 0a 32 0d 0a 5b 5d 0d 0a .. .. .. .. .. .. .. .. .. ....2..[]..
2021-01-04 18:43:53.907 (Connexoon) Processing 'ReadEvent' message
2021-01-04 18:43:53.907 (Connexoon) Received 5 bytes of data
2021-01-04 18:43:53.907 (Connexoon) 30 0d 0a 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 0....
2021-01-04 18:43:53.907 (Connexoon) Pushing 'onMessageCallback' on to queue
2021-01-04 18:43:53.907 (Connexoon) Processing 'onMessageCallback' message
2021-01-04 18:43:53.907 (Connexoon) Calling message handler 'onMessage'.
2021-01-04 18:43:53.907 (Connexoon) []
2021-01-04 18:43:56.462 (Connexoon) Pushing 'DisconnectDirective' on to queue
2021-01-04 18:43:56.462 (Connexoon) Processing 'DisconnectDirective' message
2021-01-04 18:43:56.462 (Connexoon) Disconnect directive received for 'tahomalink.com:443'.
2021-01-04 18:43:56.462 (Connexoon) Handling TCP disconnect, socket (tahomalink.com:443) is connected
2021-01-04 18:43:56.463 (Connexoon) Pushing 'DisconnectedEvent' on to queue
2021-01-04 18:43:56.513 (Connexoon) Processing 'DisconnectedEvent' message
2021-01-04 18:43:56.513 (Connexoon) Disconnect event received for 'tahomalink.com:443'.
2021-01-04 18:43:56.514 (Connexoon) Pushing 'onDisconnectCallback' on to queue
2021-01-04 18:43:56.514 (Connexoon) Pushing 'onStopCallback' on to queue
2021-01-04 18:43:56.514 (Connexoon) Processing 'onDisconnectCallback' message
2021-01-04 18:43:56.514 (Connexoon) Calling message handler 'onDisconnect'.
2021-01-04 18:43:56.514 (Connexoon) Processing 'onStopCallback' message
2021-01-04 18:43:56.514 (Connexoon) Calling message handler 'onStop'.
2021-01-04 18:43:56.514 (Connexoon) Deallocating connection object 'Secure Connection' (tahomalink.com:443).
2021-01-04 18:43:56.462 Status: (Connexoon) Stop directive received.
2021-01-04 18:43:56.462 Status: (Connexoon) Exiting work loop.
2021-01-04 18:43:56.562 Status: (Connexoon) Stopping threads.
2021-01-04 18:43:56.562 Status: (Connexoon) Stopped.
2021-01-04 18:43:56.562 Status: (Connexoon) Started.
2021-01-04 18:43:56.744 Status: (Connexoon) Entering work loop.
2021-01-04 18:43:56.744 Status: (Connexoon) Initialized version 2.0.2, author 'nonolk'
2021-01-04 18:43:56.748 Status: (Connexoon) Starting Tahoma blind plugin
2021-01-04 18:43:56.903 Error: (Connexoon) Tahoma error must reconnect
2021-01-04 18:43:56.903 Error: (Connexoon) Too much connexions must wait
2021-01-04 18:44:06.775 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:44:16.796 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:44:26.766 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:44:36.786 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:44:46.757 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:44:56.776 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:06.798 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:16.769 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:26.790 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:36.809 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:46.778 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:56.797 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:06.817 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:16.787 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:26.806 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:36.777 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:46.798 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:56.819 Status: (Connexoon) Too much connections waiting before authenticating again
© 2012-2021 Domoticz | WWW: Domoticz.com
