Domoticz version stable 2020.2
Chrominator
Message par Chrominator »
Nouvelle mise à jour.
Le signal fait référence à une version 11995, l'historique des versions parle de 2020.2 - Etrange.
Screenshot_2020-04-28 Domoticz_dev.png (11.66 Kio) Consulté 4890 fois
Version 2020.2 (April 26th 2020)
- Implemented: GUI: New Update controller code
- Implemented: GUI: Real-time updates of history-logs on device / scene changes
- Fixed: Battery level Real-time updates
- Fixed: Daikin wifi adaptor module
- Fixed: Delete device now propagates to all relevant tables
- Fixed: Possible security issue in the websocket layer
- Fixed: Unwanted RFY protection popup
- Updated: BuienRadar, Now possible to enter Station_ID or Latitude/Longitude
- Updated: Deprecated Google Cloud Messaging system(gcm) replaced by Firebase Cloud Messaging (fcm)
- Updated: dzVents version 3.0.2 ( https://www.domoticz.com/wiki/DzVents:_ ... ng#History )
- Updated: OpenZWave configuration files
- Updated: OpenZWave library for windows
- Updated: MQTT add option to enable/disable loop prevention
- Changed: Removed external library dependencies from repository
- Updated: Translations
- Updated: TTNMQTT, improved handling CayenneLPP channels
- For a full overview visit: https://www.domoticz.com/wiki/Domoticz_ ... _-_Commits for details
RFXtrx433 USB Ver Pro1/1043
Rtl433 RTL-SDR receiver
RFLink Gateway
Zigbee SLZB-06
denis_brasseur
Re: Domoticz version stable 2020.2
Message par denis_brasseur »
Je me suis fais la même remarque, étrange.
On March 22nd, 2020 a new method for version labeling is introduced. Releases (previously referred to with the label 'Stable') will have a major release number formed by the 4 digit year, a dot and a working number. The first stable release in 2020 is 2020.1, the second will be 2020.2, etc.. Hotfixes to these releases will receive an additional working number so the first hotfix applied to release 2020.1 will be 2020.1.1 Beween release and beta, the development versions are labeled 2020.2 development (build: 11831) Approximately 4 weeks before a release, a beta release will be available for testing. It will be labeled like 2020.2 beta (build: 12007). The number after build: is the github commit number.
Chrominator
Pas en panne une fois la mise à jour faite.
Screenshot_2020-04-28 Domoticz_dev(1).png (20.21 Kio) Consulté 4882 fois
RFLink Gateway
Zigbee SLZB-06
jcb2
Message par jcb2 »
Deux tentatives depuis la page internet sans succès.
Une tentative depuis la console linux et c'est passé.
Rien a signaler cette fois.
NUC en Debian 13 via Proxmox
Beaucoup de SonOff flashé Tasmota (en Wifi)
RF Link - Stations Netatmo
Box Somfy Connexoon pour volets Vélux et stores Somfy
... et pour combiner le tout, plein de script LUA pour automatiser la maison
klarf
Message par klarf »
la dernière mise à jour semblait compliqué pour certain (2020.1), j'avais fait un backup du dossier domoticz avant la mise à jour.
Pour la version 2020.2 je n'ai vu aucun retour négatif, j'ai donc ce matin fait une mise à jour complète :
sudo apt-get update && sudo apt-get -y upgrade && sudo apt-get -y dist-upgrade && sudo rpi-update
puis mise à jour (via commande git pull) de zigbee2mqtt ainsi que des plugin, dont zigbee2mqtt et de Domoticz via l'interface sur mon navigateur internet.
Depuis j'ai mon rasberry qui plante aléatoirement, j'ai parfois que domoticz, mais après j'ai un écran figé quand je branche le raspberry en hdmi. Cela arrive environ toute les 10-20 minutes.
Je n'arrive pas à comprendre pourquoi. J'ai mis à jour sous Buster depuis plusieurs mois déjà, là tout était stable... Je n'aurais pas du mettre à jour mais le panneau "update" en haut de domoticz m'énervé.
J'ai essayé de mettre mon backup en 4.10717 mais cela ne marche pas.
Dans le log de domoticz je n'ai aucune erreur fatale avant la fin de celui ci, pareil sur zigbee2mqtt.
Est ce qu'il y a des autres retours comme le miens ?
Merci d'avance
edit : sans explication j'ai perdu mes dispositifs zwave.
2020-05-01 17:22:38.804 Status: OpenZWave: Version: 1.6-1033-g3661f170
2020-05-01 17:22:40.011 Status: OpenZWave: User Alert - Manufacturer_specific.xml out of Date
2020-05-01 17:22:40.011 Status: OpenZWave: ManufacturerSpecificDB Ready
Et ensuite ça planté (raspberry complet)
