[Résolu] Error: mqtt: unknown idx received! (idx 174)
didier02
Message par didier02 »
Bonjour, j'en appelle a vos services , ..
Je me trouve avec une errreur de MQTT dans mes logs
2022-12-20 11:24:36.043 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:36.670 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:37.247 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:38.455 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:39.078 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:39.645 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:40.754 zigate: UpdateDevice - (chambre juliane) 0:25.2;46.0;1
2022-12-20 11:24:40.771 zigate: UpdateDevice - (chambre juliane) 25.2:25.2
2022-12-20 11:24:40.244 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:41.056 1wire: Temp (ECS depart chaudiere)
2022-12-20 11:24:41.048 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:41.491 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:42.046 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:42.229 Error: zigate: Device 188 not found !!!
2022-12-20 11:24:42.329 Error: zigate: Device 189 not found !!!
2022-12-20 11:24:42.428 Error: zigate: Device 190 not found !!!
2022-12-20 11:24:43.204 teleinfo edf: General/kWh (Teleinfo kWh Heures Creuses)
2022-12-20 11:24:43.219 teleinfo edf: General/kWh (Teleinfo kWh Heures Pleines)
2022-12-20 11:24:43.234 teleinfo edf: P1 Smart Meter (Teleinfo kWh Total)
2022-12-20 11:24:43.246 teleinfo edf: Current (Teleinfo Courant)
2022-12-20 11:24:43.253 teleinfo edf: General/Percentage (Teleinfo Pourcentage de Charge)
2022-12-20 11:24:43.305 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:43.893 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:44.475 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:45.045 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:45.673 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:46.272 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:46.842 Error: mqtt: unknown idx received! (idx 174)
2022-12-20 11:24:47.059 1wire: Temp (Temp départ chauffages)
2022-12-20 11:24:47.460 Error: mqtt: unknown idx received! (idx 174)
ca fait 2 jours que je cherche , mais je ne trouve rien , j'ai re installé des sauvegardes de bases de données et toujours cette erreur :
j'ai installé mqtt exploreur , où il y a bien cette erreur , mais je sais pas quoi en faire ...
je précise que bien sur j'ai pas de idx 174 nul par !!
j'ai désactive mqtt, l'erreur s'arrête
j'ai désactivé tous mes dispositifs tasmotat , l'erreur est toujours là ...
Dernière modification par didier02 le 20 déc. 2022, 21:45, modifié 1 fois.
didier02
Re: Error: mqtt: unknown idx received! (idx 174)
je viens de recrée un capteur virtuel idx 174 l'erreur toujours présente
je le surprime toujours là également :x
Dans la console de tamota je le retrouve egalement
17:20:15.195 MQT: domoticz/in = {"idx":170,"nvalue":0,"svalue":"0.000","Battery":100,"RSSI":10}
17:20:15.202 MQT: tele/tasmota_9DED5A/SENSOR = {"Time":"2022-12-20T17:20:15","ENERGY":{"TotalStartTime":"2022-03-07T11:20:05","Total":140.049,"Yesterday":0.382,"Today":0.575,"Period": 0,"Power": 0,"ApparentPower": 0,"ReactivePower": 0,"Factor":0.00,"Voltage":234,"Current":0.000}}
17:20:15.226 RUL: ENERGY#TOTAL performs "var1 140.049"
17:20:15.234 MQT: stat/tasmota_9DED5A/RESULT = {"Var1":"140.049"}
17:20:15.246 RUL: ENERGY#TOTAL performs "Mult1 1000"
17:20:15.255 MQT: stat/tasmota_9DED5A/RESULT = {"Mult1":"140049.000"}
c'est quoi ce machin !! 9DED5A/SENSOR !!!
Si tu coupes ton tasmota, l'erreur est toujours là ?
Si oui, dans ton tasmota>Configuration, configure domoticz, tu as peut-être ce 174 de renseigné.
C'est quoi ton périphérique tasmota ? Est-ce qu'il mesure la puissance ?
didier02
bonjour , Neutrino, et merci de t'intéresser a mon cas ..
desolé , je ne sais pas comment on coupe tasmota ...
j'ai désactivé mes modules sonoff , j'ai 2 pow R2 ( lecture de puissance) et 3 basic ( juste inter) l'erreur été toujours là ..
de plus si je décoche log level erreur , dans config/materiel, j'ai plus l'erreur, .. normal ...
il semblerait que cela vienne d'un essais de compteur que j'ai fais, et supprimé , mais du coup je le retrouve plus !!!
didier02
bon, j'ai trouvé le fautif !!
Nom d'Hôte tasmota-9DED5A-3418
c'est bien un module sonoff PR2 ( monitoring de puissance)
mais ,comment je peux virer ce idx 174
si je débranché le pow R2 , l'erreur s'arrete .. ..!!! :twisted:
je vais lui faire un reset !!
garycooper
Message par garycooper »
Il faut enlever l'idx que tu as mis dans le paramètre "Domoticz" sur l'interface web tasmota de ton pow R2. Si tu ne peux pas récupérer l'info qui transite en mqtt, c'est que soit ton device n'est pas bon (il y a plusieurs types de compteurs dans domoticz, pas facile de choisir le bon), soit c'est le paramétrage du module tasmota qui n'est pas bon.
Dernière modification par garycooper le 11 janv. 2023, 00:08, modifié 1 fois.
didier02
bonjour et merci de l idée Garycooper, mais j'ai préféré faire un reset et tout est rentré dans l'ordre, ... un device qui n'a pas était supprimé entièrement ... le plus dur à était de trouver le responsable ...
merci de vos aides ... :D
