en essayant de mettre des ports fixes pour ma zigate et mon rfxcom je me suis aperçu qu ils avaient les mêmes id vendor et idpoduct
je ne sais pas comment faire
ci joint la copie des interrogations du pi3
pi@raspberrypi:~ $ sudo udevadm info --query=all --name=ttyUSB0
P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/ttyUSB0/tty/ttyUSB0
N: ttyUSB0
L: 0
S: serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0
S: serial/by-id/usb-FTDI_ZiGate_ZIGATE+-if00-port0
E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/ttyUSB0/tty/ttyUSB0
E: DEVNAME=/dev/ttyUSB0
E: MAJOR=188
E: MINOR=0
E: SUBSYSTEM=tty
E: USEC_INITIALIZED=337821757898
E: ID_PATH=platform-3f980000.usb-usb-0:1.3:1.0
E: ID_PATH_TAG=platform-3f980000_usb-usb-0_1_3_1_0
E: ID_VENDOR=FTDI
E: ID_VENDOR_ENC=FTDI
E: ID_VENDOR_ID=0403
E: ID_MODEL=ZiGate
E: ID_MODEL_ENC=ZiGate
E: ID_MODEL_ID=6015
E: ID_REVISION=1000
E: ID_SERIAL=FTDI_ZiGate_ZIGATE+
E: ID_SERIAL_SHORT=ZIGATE+
E: ID_TYPE=generic
E: ID_BUS=usb
E: ID_USB_INTERFACES=:ffffff:
E: ID_USB_INTERFACE_NUM=00
E: ID_USB_DRIVER=ftdi_sio
E: DEVLINKS=/dev/serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0 /dev/serial/by-id/usb-FTDI_ZiGate_ZIGATE+-if00-port0
E: TAGS=:systemd:
E: CURRENT_TAGS=:systemd:
pi@raspberrypi:~ $ sudo udevadm info --query=all --name=ttyUSB1
P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/ttyUSB1/tty/ttyUSB1
N: ttyUSB1
L: 0
S: serial/by-path/platform-3f980000.usb-usb-0:1.1.3:1.0-port0
S: serial/by-id/usb-RFXCOM_RFXtrx433XL_DO2Y2PEU-if00-port0
E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/ttyUSB1/tty/ttyUSB1
E: DEVNAME=/dev/ttyUSB1
E: MAJOR=188
E: MINOR=1
E: SUBSYSTEM=tty
E: USEC_INITIALIZED=9729691
E: ID_PATH=platform-3f980000.usb-usb-0:1.1.3:1.0
E: ID_PATH_TAG=platform-3f980000_usb-usb-0_1_1_3_1_0
E: ID_VENDOR=RFXCOM
E: ID_VENDOR_ENC=RFXCOM
E: ID_MODEL=RFXtrx433XL
E: ID_MODEL_ENC=RFXtrx433XL
E: ID_MODEL_ID=6015
E: ID_REVISION=1000
E: ID_SERIAL=RFXCOM_RFXtrx433XL_DO2Y2PEU
E: ID_SERIAL_SHORT=DO2Y2PEU
E: ID_TYPE=generic
E: ID_BUS=usb
E: DEVLINKS=/dev/serial/by-path/platform-3f980000.usb-usb-0:1.1.3:1.0-port0 /dev/serial/by-id/usb-RFXCOM_RFXtrx433XL_DO2Y2PEU-if00-port0
E: TAGS=:systemd:
qu en pensez vous
probleme affectation usb
Re: probleme affectation usb
Il faut que tu rajoutes un autre paramètre qui est différent entre les deux.
mike913
- Contact :
Essaye la commande ;
udevadm info -a -n /dev/ttyUSB0 | grep '{product}' | head -n1DS718+ 2 x 3To(SHR) - Firmware: DSM 7.0.1-42218
FreeBox Delta
https://meteo.folcke.net
https://wiki.folcke.net
FreeBox Delta
Chrominator
Si ton OS te le permet, utilise plutôt la désignation des ports par leur identification dans le système, c'est plus simple :
- Pièces jointes
- Capture d’écran 2023-01-11 043431.png (13.97 Kio) Consulté 774 fois
RFXtrx433 USB Ver Pro1/1043
Rtl433 RTL-SDR receiver
RFLink Gateway
Zigbee SLZB-06
RFLink Gateway
Zigbee SLZB-06
thierry73290
j ai débranché la zigate, j ai assigné le rfxcom sur le port 11
après avoir rebranché la zigate elle a fini de s installer et tous marche
