Python non installé
nene82
Python non installé
Message par nene82 »
Je viens ici chercher de l'aide, car j'essaie en vain d'installer Python et ses librairies sur mon DOMOTICZ et bien sur je n'y arrive pas.
à propos.jpg (20.02 Kio) Consulté 492 fois
et les logs de domoticz après reboot le confirment,
  • Tout
    Etat
    Filtre: X
    2024-02-29 10:02:12.901 Status: Domoticz V2024.4 (c)2012-2024 GizMoCuz
    2024-02-29 10:02:12.901 Status: Build Hash: 731719420, Date: 2024-01-30 09:16:34
    2024-02-29 10:02:12.901 Status: Startup Path: /home/user/domoticz/
    2024-02-29 10:02:12.976 Status: PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
    2024-02-29 10:02:13.140 Status: WebServer(HTTP) started on address: :: with port 8080
    2024-02-29 10:02:13.148 Status: WebServer(SSL) started on address: :: with port 443
    2024-02-29 10:02:13.156 Status: RxQueue: queue worker started...
    2024-02-29 10:02:13.156 Status: TCPServer: shared server started...
    2024-02-29 10:02:15.158 Status: RfxCom: Worker started...
    2024-02-29 10:02:15.164 Status: Pi: Hardware Monitor: Started (OStype Linux)
    2024-02-29 10:02:15.166 Status: Nas: Worker started...
    2024-02-29 10:02:15.167 Status: Météo Virtuelle: Using Domoticz default location from Settings as Location.
    2024-02-29 10:02:15.167 Status: Météo Virtuelle: Started...
    2024-02-29 10:02:15.169 Status: NotificationSystem: thread started...
    2024-02-29 10:02:15.169 Status: EventSystem: reset all events...
    2024-02-29 10:02:15.175 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/08 - lecture et stockage variable toute les heures.lua
    2024-02-29 10:02:15.176 Status: EventSystem: reset all device statuses...
    2024-02-29 10:02:15.206 Status: EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
    2024-02-29 10:02:15.206 Status: EventSystem: Queue thread started...
    2024-02-29 10:02:15.206 Status: EventSystem: Started
j'ai suivi ce tuto https://pon.fr/gestionnaire-de-plug-in- ... -domoticz/, le plugin PP-MANAGER est à priori bien installé, les droits ont l'ai correct sur le fichier "plugin.py" mais manifestement je ne comprends certainement pas bien le déroulé du truc.
Est ce que quelqu'un peut me mettre sur une piste,
je vous remercie par avance,
JP
Re: Python non installé
Je viens de déplacer ton sujet dans la section déidée à l'installation sous Linux.
Tu pourrais nous indiquer sur quel système tu essayes de faire ton installation (OS + version) ?
nene82
Oui merci Keros, évidemment!
Donc pour essayer de répondre à ta demande, Domoticz est installé sous une VM freebox.
Ci dessous les informations que me renvoie le système lors de la connexion en SSH : Linux Domoticz 5.10.0-28-arm64 #1 SMP Debian 5.10.209-2 (2024-01-31) aarch64.
Est que ceci répond à ta question?
salinois
Message par salinois »
bonjour,
je crois que j'avais suivi ce qui était sur ce site : https://linuxhint.com/install-python-debian-10
Salinois
Dernière modification par Keros le 29 févr. 2024, 20:40, modifié 1 fois.
Raison : Modification des balises
nene82
Et voilà!
Ce lien fonctionne aussi!https://computingforgeeks.com/how-to-in ... t=cmp-true
merci salinois!
Merci à tous!
à bientôt!
