LYWSD03MMC flasher avec firmware zigbee
VBill
Message par VBill »
Je viens de tester un LYWSD03MMC flasher avec un firmware zigbee (https://github.com/pvvx/ATC_MiThermometer)
Zigbeefordomoticz le decouvre et 4 dispositif sont créé dans domoticz mais les valeurs sont a zero.
version Plugin: 7.1.012 [5.260]
Firmware: Znp - Z-Stack 3.30+ (build 20220219)
Je vous joint les infos de l'objet :
{"Filename":"LYWSD03MMC-z.json","Configuration":{"_comment":"","_version":"","_blakadder":"","_source":"","Ep":{"01":{"0000":"","0001":"","0003":"","0204":"","0402":"","0405":"","0019":"","Type":"Temp+Hum/Voltage/Temp/Humi"}},"Type":"","ClusterToBind":null,"ConfigureReporting":{},"ReadAttributes":{"0000":[],"0402":[],"0001":[],"0019":[],"0405":[],"0204":[]},"Param":{},"GroupMembership":{}},"rawInfos":{"Version":"3","ZDeviceName":"","Status":"inDB","SQN":"02","Ep":{"01":{"0000":{"0004":"Xiaomi","0000":3,"0001":0,"0005":"LYWSD03MMC-z","0007":3},"0001":{},"0003":{},"0204":{},"0402":{},"0405":{},"0019":{},"ClusterType":{"472":"Temp+Hum","473":"Voltage","474":"Temp","475":"Humi"}}},"Heartbeat":"157","RIA":"5","LQI":127,"Battery":{},"Model":"LYWSD03MMC-z","ForceAckCommands":[],"MacCapa":"80","IEEE":"a4c138c6c64138c5","Type":"Voltage/Temp/Humi","ProfileID":"0104","ZDeviceID":"0302","App Version":0,"Attributes List":{},"DeviceType":"RFD","HW Version":"","Last Cmds":[],"LogicalType":"End Device","Manufacturer":"1141","Manufacturer Name":"Xiaomi","NbEp":"1","PowerSource":"Battery","ReadAttributes":{"Ep":{"01":{"0000":{"TimeStamp":1716923924,"iSQN":{"fffe":"01","0004":"10","0000":"10","0001":"10","0005":"10","0007":"10"},"Attributes":{"fffe":"86"},"ZigateRequest":{}},"0402":{"TimeStamp":1716923924,"iSQN":{"0000":"05","0001":"05","0002":"05","0003":"05","fffd":"05","fffe":"05"},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":1716923924,"iSQN":{"0000":"06","0001":"06","0010":"06","0011":"06","0012":"06","0013":"06","0020":"07","0021":"07","0030":"07","0031":"07","0032":"07","0033":"07","0034":"08","0035":"08","0036":"08","0037":"08","0038":"08","0039":"08","003a":"09","003b":"09","003c":"09","003d":"09","003e":"09","fffd":"09","fffe":"0a"},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":1716923924,"iSQN":{"0000":"0b","0001":"0b","0002":"0b","0003":"0b","0004":"0b","0005":"0b","0006":"0c","0007":"0c","0008":"0c","0009":"0c","000a":"0c","fffd":"0c","fffe":"0d"},"Attributes":{},"ZigateRequest":{}},"0405":{"TimeStamp":1716923924,"iSQN":{"0000":"0e","0001":"0e","0002":"0e","0003":"0e","fffd":"0e","fffe":"0e"},"Attributes":{},"ZigateRequest":{}},"0204":{"TimeStamp":1716923924,"iSQN":{"0001":"0f","0000":"0f","0002":"0f","fffd":"0f","fffe":"0f"},"Attributes":{},"ZigateRequest":{}}}}},"ReceiveOnIdle":"","Stack Version":"","Stamp":{"time":1716923932.122138,"Time":"2024-05-28 21:18:52","MsgType":"8011","LastSeen":1716923932},"ZCL Version":3,"Health":"Live","Capability":["Reduced-Function Device","Standard security","NwkAddr should be allocated"],"ZCLSQN":"18","ZDPSQN":"0e","RollingLQI":[131,134,127],"WriteAttributes":{"Ep":{"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}},"PairingInProgress":false,"Epv2":{"01":{"ProfileID":"0104","ZDeviceID":"0302","ClusterIn":{"0000":{},"0001":{},"0003":{},"0204":{},"0402":{},"0405":{}},"ClusterOut":{"0019":{}}}},"ZDeviceVersion":"0001","ConfigSource":"8043","PairingTime":1716923924.101034,"Bind":{"01":{"0000":{"Target":"0000","Stamp":1716923924,"Phase":"requested","Status":"","i_sqn":"07"},"0001":{"Target":"0000","Stamp":1716923924,"Phase":"requested","Status":"","i_sqn":"08"},"0003":{"Target":"0000","Stamp":1716923924,"Phase":"requested","Status":"","i_sqn":"09"},"0204":{"Target":"0000","Stamp":1716923924,"Phase":"requested","Status":"","i_sqn":"0a"},"0402":{"Target":"0000","Stamp":1716923924,"Phase":"requested","Status":"","i_sqn":"0b"},"0405":{"Target":"0000","Stamp":1716923924,"Phase":"requested","Status":"","i_sqn":"0c"}}},"BindingTable":[{"Devices":[],"SQN":0,"Status":"","TimeStamp":1716923924,"Time":1716923924}],"ConfigureReporting":{"Ep":{"01":{"0402":{"TimeStamp":1716923924.1149077,"iSQN":{"0000":"02"},"Attributes":{"0000":"00"},"ZigateRequest":{}},"0001":{"TimeStamp":1716923924.1162558,"iSQN":{"0000":"03","0020":"03","0021":"03"},"Attributes":{},"ZigateRequest":{}},"0405":{"TimeStamp":1716923924.119009,"iSQN":{"0000":"04"},"Attributes":{},"ZigateRequest":{}}}}},"CertifiedDevice":false,"_rawNodeDescriptor":"1141019401942a0000804a4002","Max Buffer Size":"4a","Max Rx":"0194","Max Tx":"0194","macapa":"80","bitfield":"4002","server_mask":"2a00","descriptor_capability":"00"}}
Capture d'écran 2024-05-28 213343.png (44.77 Kio) Consulté 577 fois
Dernière modification par Keros le 28 mai 2024, 22:10, modifié 1 fois.
Raison : Ajout des balises
Re: LYWSD03MMC flasher avec firmware zigbee
As-tu utiliser le bon firmware ? ne serait-ce pas celui ci qui convient ?
https://github.com/devbis/z03mmc
VBill
Message par VBill »
Oui c'est le même (mais anciènne version du flasher 6.2 pour 7.8 actuellement) en anciènne version 1.1 (le premier firmware)
https://github.com/pvvx/ATC_MiThermomet ... s/tag/V1.1
actuellement on est en 4.6
https://github.com/pvvx/ATC_MiThermomet ... s/tag/v4.6
version 7.8 du flacher:
https://pvvx.github.io/ATC_MiThermomete ... asher.html
Dernière modification par Keros le 02 juin 2024, 15:15, modifié 1 fois.
il y a une différence alors car, pour celui que j'ai mentionné il s'agit d'un Temp/Humi alors que ce qui est remonté avec ce firmware c'est un autre type de device.
VBill
Message par VBill »
Bonsoir Pipiche
Je ne comprends pas ce que tu veux dire par autre type de device, regarde la capture d'écran, je vois bien un temp, un humi, un volt et un temp/humi qui ont été créé.
Mais pas de valeurs remontées tout est à zéro.
Peut être une évolution du codage entre la version 1.1 et la dernière ?
Si ça peut aider dis moi les infos que tu souhaite.
Dernière modification par Keros le 03 juin 2024, 23:19, modifié 1 fois.
Le Voltage ? Le plugin ne masque pas l'info d'habitude ?
Tu as fait des configurations particulières dans ton plugin ?
Pour moi le device ne renvoie pas d’info.
Donc si tu peux sniffer le traffic on pourra voir ce qu’il se passe
