Problème d'installation sous Windows
JPGO
Message par JPGO »
Je voulais tester le plugin mais cela ne se passe pas bien :)
Contexte:
Windows 11
Domoticz 2025.1 build 16657
Zip de la 7 Stable récupéré sur GITHUB.
2025-04-29 08:56:42.298 Error: Zigbee for Domoticz: (Zigate) failed to load 'plugin.py', Python Path used was 'C:\Home\Domoticz\plugins\Domoticz-Zigbee\;C:\Program Files (x86)\Python312-32\python312.zip;C:\Program Files (x86)\Python312-32\DLLs;C:\Program Files (x86)\Python312-32\Lib;C:\Home\Domoticz;C:\Program Files (x86)\Python312-32;C:\Program Files (x86)\Python312-32\Lib\site-packages'.
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: Traceback (most recent call last):
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: File "C:\Home\Domoticz\plugins\Domoticz-Zigbee\plugin.py", line 123, in <module>
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: from Classes.NetworkMap import NetworkMap
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: File "C:\Home\Domoticz\plugins\Domoticz-Zigbee\Classes\NetworkMap.py", line 40, in <module>
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: from Modules.zb_tables_management import (
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: File "C:\Home\Domoticz\plugins\Domoticz-Zigbee\Modules\zb_tables_management.py", line 29, in <module>
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: from sqlite3 import Timestamp
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: File "C:\Program Files (x86)\Python312-32\Lib\sqlite3\__init__.py", line 57, in <module>
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: from sqlite3.dbapi2 import *
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: File "C:\Program Files (x86)\Python312-32\Lib\sqlite3\dbapi2.py", line 27, in <module>
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: from _sqlite3 import *
2025-04-29 08:56:42.330 Error: Zigbee for Domoticz: ImportError: DLL load failed while importing _sqlite3: La procédure spécifiée est introuvable.
2025-04-29 08:57:52.853 Error: Zigbee for Domoticz hardware (48) thread seems to have ended unexpectedly
J'ai pas trop d'idées par ou chercher...
Re: Problème d'installation sous Windows
Fais des recherches sur le forum. Le cas Windows a été traité
Voir le wiki également où il y a une page pour windows
JPGO
Message par JPGO »
Je suis allé sur le Wiki, mais j'installe la version 7 et il me semble bien qu'il en est resté à la version 5 (forums Français et Anglais)
Et j'ai rien trouvé qui ressemble à mon problème dans la section Windows.
Le problème a déjà été posé.
@JPGO,
  • Pourquoi avoir ouvert un nouveau sujet ?
  • Ton plan B n'a pas fonctionné ?
  • Gemini ne t'as pas donné la réponse ?
JPGO
Message par JPGO »
J'ai ouvert un nouveau problème mais effectivement j'aurais pas du.
Mon plan B basé sur Zibgee2MQTT fonctionne depuis plusieurs mois mais comme j'ai deux clés (une Zigate et une SMLIGHT) je voulais voir ce que donnais les nouvelles versions de zigbeefordomoticz. Mias bon vu l'accueil, je vais continuer avec le plan B et ne plus venir vous déranger.
Dernière modification par Keros le 02 mai 2025, 18:22, modifié 1 fois.
Raison : Citation supprimée. Merci de ne pas citer le message précédent lors d'une réponse directe
Si tu essayais de faire fonctionner une ZiGate sur un DomoticZ tournant sous Windows, tu es dans le pire des cas :
  • Comme indiqué il y a deux ans, aucun des développeurs du plugin n'a son DomoticZ fonctionnant sous Windows. Aucun test n'est fait sur cette plateforme.
  • Nous avons arrêté le support des ZiGates depuis 3 ans. Plus aucun développeur du plugin n'en n'utilise. Je suis resté avec ma ZiGate (et son vieux firmware) jusqu'en novembre dernier pour vérifier que les nouvelles versions du plugin restaient compatibles.
Concernant notre accueil, tu nous as qualifiés de clown ... Désolé si nous sommes un peu moins bienveillants envers toi.
Bonne continuation avec Zibgee2MQTT.
Je viens d'enlever les deux derniers messages de Lost et JGPO qui n'apporte pas grand chose au sujet dont il est question ici.
@JGPO, tu utilises souvent des qualificatif négatif envers les autres membres ou leurs actions. Si cela continu, je prendrai des mesures afin que les échanges sur ce forum restent bienveillant.
Verrouillé
