New RFLink firmware (R44) now available!
Stuntteam
Message par Stuntteam »
Brand new RFLink Gateway firmware adds support for Ikea Ansluta, Philips Living Colors Gen1, MySensors devices and has "Mini" GPIO.
For Ansluta or Living Colors you will need a CC2500 module. Details on how to connect these modules are on the Wiring details page.
Changelog:
R44:
- New Device: Ikea Ansluta (2.4 Ghz device, CC2500 transceiver required)
- New Device: Philips Living Colors Generation 1 (2.4 Ghz device, CC2500 transceiver required)
- New Device: Friedland DC44
- New Device: Warema EWFS shutters and awnings
- New Device: Bosch DID09T951, Bosch DID09T950 and compatible ventilation units
- New Device: Siemens SF-01 and compatible ventilation units
- New Device: Wave Design SF-01 and compatible ventilation units
- New Device: Visonic MCT-302 open and close signal
- New Device: Ningbo KD-205-1 switch set
- New Device: Steffen Power Switch (1204380 3M)
- New Device: Bresser weather sensor
- New Device: RFTech 210TX weather sensor
- New Feature: Bluetooth LE Advertisement packet sniffing *experimental* (NRF24L01 required, needs to be wired for MiLight)
- New Feature: MySensors packet sniffing *experimental* (NRF24L01 required, needs to be wired for MiLight)
- New Device: MySensors temperature and humidity devices (more types to follow) (NRF24L01 required, needs to be wired for MiLight)
- Fixed: Improved OWL CM130 recognition
- Fixed: Revolt power reporting corrected
- Fixed: RFmeter values presented in hexadecimal
- Fixed: Improved Baldr signal recognition
- Added: Friedland PIR checksum calculation
- Added: GPIO 4 input and 4 output pins can be used as on/off or push button devices
jackslayter
Re: New RFLink firmware (R44) now available!
Message par jackslayter »
yes thank you, now I can use my Revolt power
jackslayter
hi, why I don't Energy Usage (blue)?
thank you
ganq
Message par ganq »
quelq'un a t-il testé l'integration de mysensor dans le rf link ?
Rflink recoit les trames, je ne sais pas si les modifs ont ete faites du coté de domoticz pour les prendre en compte.
Il faut regarder dans les sources de Domoticz sur GitHub
jackslayter
ok.
par contre ils devaient pas réduire le nombre de trames décodées? car la j'en ai toujours 50/minute
Les trames de ?
Mysensors ?
jackslayter
les trames envoyées par les revolt, qui spam le log de domoticz
Tu ne peux rien faire, ce sont les prises qui sont comme cela. A 12€ la prise il faut bien un inconvegnant quand meme.
jackslayter
Oui, surtout que je les ai eu à 9€ :)
