led RGB my sensors pb integration dans domoticz [RESOLU]
youn
Message par youn »
bonjour,
je fabrique un controleur led rgb j'ai utiliser le skech de my sensors "RGBdimmerV2"
https://www.mysensors.org/hardware/rgbw-controller
j'ai un probleme j'arrive pas a voir ma gateway my sensors dans domoticz
j'ai modifier le sketch pour fonctionner directement avec la carte ethernet w5100
pas de probleme pour la compilation mais domoticz lui ne vois rien
dans domotic j'ai selectionner "MySensors Gateway with LAN interface" j'ai essayer aussi avec "Limitless/AppLamp with LAN interface " mais rien n'y fait
voici mon code : dite moi si sa vous parais correct et des piste pour résoudre mon probleme
merci d'avance
Based on the MySensors Project: http://www.mysensors.org
This sketch controls a (analog)RGBW strip by listening to new color values from a (domoticz) controller and then fading to the new color.
Version 2.0 - Updated to MySensors 2 and changed fading
Version 1.0 - Changed pins and gw definition
Version 0.9 - Oliver Hilsky
TODO
safe/request values after restart/loss of connection
#define SN   "RGBW Schrankwand"
#define SV   "v2.0 13112016"
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
//#define MY_RADIO_NRF24
//#define MY_RADIO_NRF5_ESB
//#define MY_RADIO_RFM69
//#define MY_RADIO_RFM95
// Enable gateway ethernet module type
#define MY_GATEWAY_W5100
// W5100 Ethernet module SPI enable (optional if using a shield/module that manages SPI_EN signal)
//#define MY_W5100_SPI_EN 4
// Enable Soft SPI for NRF radio (note different radio wiring is required)
// The W5100 ethernet module seems to have a hard time co-operate with
// radio on the same spi bus.
#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
#define MY_SOFTSPI
#define MY_SOFT_SPI_SCK_PIN 14
#define MY_SOFT_SPI_MISO_PIN 16
#define MY_SOFT_SPI_MOSI_PIN 15
#endif
// When W5100 is connected we have to move CE/CSN pins for NRF radio
#ifndef MY_RF24_CE_PIN
#define MY_RF24_CE_PIN 5
#endif
#ifndef MY_RF24_CS_PIN
#define MY_RF24_CS_PIN 6
#endif*/
// Enable UDP communication
//#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
// Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP)
#define MY_IP_ADDRESS 192,168,1,55
// If using static ip you can define Gateway and Subnet address as well
//#define MY_IP_GATEWAY_ADDRESS 192,168,178,1
//#define MY_IP_SUBNET_ADDRESS 255,255,255,0
// Renewal period if using DHCP
//#define MY_IP_RENEWAL_INTERVAL 60000
// The port to keep open on node server mode / or port to contact in client mode
#define MY_PORT 5003
// Controller ip address. Enables client mode (default is "server" mode).
// Also enable this if MY_USE_UDP is used and you want sensor data sent somewhere.
//#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
// The MAC address can be anything you want but should be unique on your network.
// Newer boards have a MAC address printed on the underside of the PCB, which you can (optionally) use.
// Note that most of the Ardunio examples use  "DEAD BEEF FEED" for the MAC address.
#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
// Enable inclusion mode
#define MY_INCLUSION_MODE_FEATURE
// Enable Inclusion mode button on gateway
//#define MY_INCLUSION_BUTTON_FEATURE
// Set inclusion mode duration (in seconds)
#define MY_INCLUSION_MODE_DURATION 60
// Digital pin used for inclusion mode button
//#define MY_INCLUSION_MODE_BUTTON_PIN  3
// Set blinking period
#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Flash leds on rx/tx/err
// Uncomment to override default HW configurations
//#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
//#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
#if defined(MY_USE_UDP)
#include <EthernetUdp.h>
#endif
#include <Ethernet.h>
#include <MySensors.h>
// library settings
//#define MY_RF24_CE_PIN 4    // Radio specific settings for RF24 - changed this!
//#define MY_RF24_CS_PIN 10 // Radio specific settings for RF24 (you'll find similar config for RFM69)
#define MY_DEBUG    // Enables debug messages in the serial log
#define MY_BAUD_RATE  9600 // Sets the serial baud rate for console and serial gateway
#define MY_SIGNING_SOFT // Enables software signing
#define MY_SIGNING_REQUEST_SIGNATURES // Always request signing from gateway
#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 // floating pin for randomness
#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01}}} // gateway addres if you want to use whitelisting (node only works with messages from this one gateway)
#include <SPI.h>
#include <MyConfig.h>
#include <Vcc.h>
#define SENSOR_ID 1
// Arduino pin attached to driver pins
#define RED_PIN 3
#define WHITE_PIN 9
#define GREEN_PIN 5
#define BLUE_PIN 6
#define NUM_CHANNELS 4 // how many channels, RGBW=4 RGB=3...
// Smooth stepping between the values
#define STEP 1
#define INTERVAL 10
const int pwmIntervals = 255;
float R; // equation for dimming curve
// Stores the current color settings
byte channels[4] = {RED_PIN, GREEN_PIN, BLUE_PIN, WHITE_PIN};
byte values[4] = {0, 0, 0, 255};
byte target_values[4] = {0, 0, 0, 255};
// stores dimming level
byte dimming = 100;
byte target_dimming = 100;
// tracks if the strip should be on of off
boolean isOn = true;
// time tracking for updates
unsigned long lastupdate = millis();
void presentation()
  // Present sketch (name, version)
  sendSketchInfo(SN, SV);
  // Register sensors (id, type, description, ack back)
  present(SENSOR_ID, S_RGBW_LIGHT, SN, true);
  // get old values if this is just a restart
  request(SENSOR_ID, V_RGBW);
void setup() {
  // Set all channels to output (pin number, type)
  for (int i = 0; i < NUM_CHANNELS; i++) {
    pinMode(channels[i], OUTPUT);
  // set up dimming
  R = (pwmIntervals * log10(2))/(log10(255));
  // init lights
  updateLights();
  // debug
  if (isOn) {
    Serial.println("RGBW is running...");
  Serial.println("Waiting for messages...");
void loop()
  // and set the new light colors
  if (millis() > lastupdate + INTERVAL) {
    updateLights();
// callback function for incoming messages
void receive(const MyMessage &message) {
  Serial.print("Got a message - ");
  Serial.print("Messagetype is: ");
  Serial.println(message.type);
  // acknoledgment
  if (message.isAck())
   	Serial.println("Got ack from gateway");
  // new dim level
  else if (message.type == V_DIMMER) {
      Serial.println("Dimming to ");
      Serial.println(message.getString());
      target_dimming = message.getByte();
      // a new dimmer value also means on, no seperate signal gets send (by domoticz)
    isOn = true;
  // on / off message
  else if (message.type == V_STATUS) {
    Serial.print("Turning light ");
    isOn = message.getInt();
    if (isOn) {
      Serial.println("on");
    } else {
      Serial.println("off");
  // new color value
  else if (message.type == V_RGBW) {
    const char * rgbvalues = message.getString();
    inputToRGBW(rgbvalues);
    // a new color also means on, no seperate signal gets send (by domoticz); needed e.g. for groups
    isOn = true;
// this gets called every INTERVAL milliseconds and updates the current pwm levels for all colors
void updateLights() {
  // update pin values -debug
  //Serial.println(greenval);
  //Serial.println(redval);
  //Serial.println(blueval);
  //Serial.println(whiteval);
  //Serial.println(target_greenval);
  //Serial.println(target_redval);
  //Serial.println(target_blueval);
  //Serial.println(target_whiteval);
  //Serial.println("+++++++++++++++");
  // for each color
  for (int v = 0; v < NUM_CHANNELS; v++) {
    if (values[v] < target_values[v]) {
      values[v] += STEP;
      if (values[v] > target_values[v]) {
        values[v] = target_values[v];
      values[v] -= STEP;
  // dimming
  if (dimming < target_dimming) {
    dimming += STEP;
    if (dimming > target_dimming) {
      dimming = target_dimming;
    dimming -= STEP;
  // debug - new values
  // set actual pin values
    if (isOn) {
      // normal fading
      //analogWrite(channels[i], dimming / 100.0 * values[i]);
      // non linear fading, idea from https://diarmuid.ie/blog/pwm-exponential-led-fading-on-arduino-or-other-platforms/
      analogWrite(channels[i], pow (2, (dimming / R)) - 1);
    } else {
      analogWrite(channels[i], 0);
// converts incoming color string to actual (int) values
// ATTENTION this currently does nearly no checks, so the format needs to be exactly like domoticz sends the strings
void inputToRGBW(const char * input) {
  Serial.print("Got color value of length: ");
  Serial.println(strlen(input));
  if (strlen(input) == 6) {
    Serial.println("new rgb value");
    target_values[0] = fromhex (& input [0]);
    target_values[1] = fromhex (& input [2]);
    target_values[2] = fromhex (& input [4]);
    target_values[3] = 0;
  } else if (strlen(input) == 9) {
    Serial.println("new rgbw value");
    target_values[0] = fromhex (& input [1]); // ignore # as first sign
    target_values[1] = fromhex (& input [3]);
    target_values[2] = fromhex (& input [5]);
    target_values[3] = fromhex (& input [7]);
  } else {
    Serial.println("Wrong length of input");
  Serial.print("New color values: ");
  Serial.println(input);
    Serial.print(target_values[i]);
    Serial.print(", ");
  Serial.println("");
  Serial.print("Dimming: ");
  Serial.println(dimming);
// converts hex char to byte
byte fromhex (const char * str)
  char c = str [0] - '0';
  if (c > 9)
    c -= 7;
  int result = c;
  c = str [1] - '0';
  if (c > 9)
    c -= 7;
  return (result << 4) | c;
Dernière modification par youn le 30 août 2017, 21:39, modifié 1 fois.
youn
Re: led RGB my sensors pb integration dans domoticz
Message par youn »
j''ai lu comme quoi on pouvais voir le dialogue mysensors avec "TELNET" j'ai utiliser putty
voici ce que j'ai [img]
putty telnet.PNG (13.11 Kio) Consulté 7175 fois
[/img]
voici ce que me retourne le debug
[img]
[/img]
il ne met met pas connect quand j'essaye avec domoticz
retour putty.PNG (30.89 Kio) Consulté 7175 fois
youn
Message par youn »
resolu
il s'agit d'un probleme de mise a jour la version maximal proposer dans OMV s'arrete a 2.2339
en cas de soucis identique a moi pense a verifer vos version les installation integre ne sont pas forcement mis a jour
:D :D
digdogger
Re: led RGB my sensors pb integration dans domoticz [RESOLU]
Message par digdogger »
j'ai eu un peu le même problème à l'époque avec mon RFLink.
Dans la liste des passerelles proposées par la version du plugin Domoticz d'OMV, il n'y avait pas le RFLink, juste le RFXcom.
Pour cette raison que j'ai tout installé sur une Raspberry Pi.
Raspberry Pi 3 + Raspbian Jessie Lite + Domoticz V4.9700 - RFlink USB V48 433.42MHz - Volets Somfy RTS - MySensors USB V2.1.1 - IDE Arduino 1.8.8
