RFLink R48 available
Stuntteam
Message par Stuntteam »
R48: (18/10/2017)
- New Device: British Gas RC Plus Thermostat
- New Device: Drayton Digistat +2RF Thermostat
- New Device: Worcester Bosch DT10RF Thermostat
- New Device: Danfoss TP4000 Thermostat
- New Device: Vaillant VRT 340f Thermostat
- New Device: CalorMatic 340f Thermostat
- New Device: Hager Flash Thermostat
- New Device: Thermoflash Thermostat
- New Device: Piloteco Thermostat
- New Device: Sanfil Thermostat
- New Device: Monomat Thermostat
- New Device: Micromat Thermostat
- New Device: Monotron Thermostat
- New Device: Mémoprog RF Thermostat
- New Device: Calidou Plus Thermostat
- New Device: Radiafonte II Thermostat
- New Device: Bellagio II Thermostat
- New Device: Verplus Thermostat
- New Device: Palatino Thermostat
- New Device: Verlys Evolution Thermostat
- New Device: Melody Evolution Thermostat
- New Device: Millenium Triphasé Thermostat
- New Device: Sensual SAS Thermostat
- New Device: Sensual Bains Thermostat
- New Device: Athena Millenium Thermostat
- New Device: Athena Plenitude Thermostat
- New Device: Brel (and compatible) light switch
- New Device: Beurer BG64 (and possibly BF100) scales
- New Device: Falmec hoods
- Added: support for X10 Marmitec DS90/DS91 tamper switch
- Fixed: Milight color issue
- Fixed: Milight brightness issue
- Fixed: Milight RGB-CCT pairing made easier with pair/unpair commands
- Fixed: Milight CRC calculation on some of the protocol versions
- Fixed: Improved Kerui D025/D026 handling
- Fixed: Improved Mertik filtering
- Fixed: bug with Europe switchset unit numbers
- Fixed: Corrected TFA timing
- Fixed: Improved Cresta packet filtering
http://www.rflink.nl/blog2/
ericd
Re: RFLink R48 available
Message par ericd »
Merci beaucoup pour le travail et l'information
Ericd
frenchyyii
Message par frenchyyii »
Idem Merci ;)
jackslayter
Message par jackslayter »
thank you
ogulf
Message par ogulf »
Merci à l'équipe de dev !
- 11 x RF660P
- 1 x FGSD-002
- 10 x F007TH
- 4 x NAS-PD02Z
- 1 x Shelly 1PM
