J'ai installé rdiff-backup sur mon raspberry sous Jessie. Lorsque je fais la commande
rdiff-backup --include /home --include /etc --include /var/www --exclude '**' / /media/disque/rpi/svg_rpiCode : Tout sélectionner
Found interrupted initial backup. Removing ...
Exception '' raised of class '<type 'exceptions.AssertionError'>':
File "/usr/lib/python2.7/dist-packages/rdiff_backup/Main.py", line 304, in error_check_Main
try: Main(arglist)
File "/usr/lib/python2.7/dist-packages/rdiff_backup/Main.py", line 324, in Main
take_action(rps)
File "/usr/lib/python2.7/dist-packages/rdiff_backup/Main.py", line 280, in take_action
elif action == "backup": Backup(rps[0], rps[1])
File "/usr/lib/python2.7/dist-packages/rdiff_backup/Main.py", line 334, in Backup
rpout.conn.fs_abilities.backup_set_globals(rpin, force)
File "/usr/lib/python2.7/dist-packages/rdiff_backup/fs_abilities.py", line 922, in backup_set_globals
dest_fsa = FSAbilities('destination').init_readwrite(Globals.rbdir)
File "/usr/lib/python2.7/dist-packages/rdiff_backup/fs_abilities.py", line 156, in init_readwrite
self.set_case_sensitive_readwrite(subdir)
File "/usr/lib/python2.7/dist-packages/rdiff_backup/fs_abilities.py", line 304, in net_case_sensitive_readwrite
assert not upper_a.lstat()
File "/usr/bin/rdiff-backup", line 30, in <module>
rdiff_backup.Main.error_check_Main(sys.argv[1:])
try: Main(arglist)
take_action(rps)
AssertionErrorMerci pour votre aide
