2 capteurs pir+dth11+relais
ledouble33
Message par ledouble33 »
bonjour , j ai recupéré un code sur le site de mysensor qui utilise 1pir+1dth11+1relais et j ai ajouté un pir de plus .
le relais ok
le dth11 temperature + humydité ok
les 2 pir s affiche dans les logs mais ils ont le meme nom donc dans les dispositifs j en ai qu un qui s affiche
si quelqu un peut m aider merci
#include <SPI.h>
#include <MySensor.h>
#include <Wire.h>
#include <DHT.h>
#include <SimpleTimer.h>
#define CHILD_ID_HUM 1
#define CHILD_ID_TEMP 2
#define CHILD_ID_MOTION 3
#define CHILD_ID_RELAY 4
#define HUMIDITY_SENSOR_DIGITAL_PIN 4
#define MOTION_SENSOR_DIGITAL_PIN 3
#define INTERRUPT MOTION_SENSOR_DIGITAL_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
#define MOTION_SENSOR_DIGITAL_PIN2 5
#define RELAY  6  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
#define RELAY_ON 0  // GPIO value to write to turn on attached relay
#define RELAY_OFF 1 // GPIO value to write to turn off attached relay
unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds) - 10mins
MySensor gw;
DHT dht;
SimpleTimer timer;
float lastTemp;
float lastHum;
boolean lastTripped;
boolean lastTripped2;
boolean metric = true;
MyMessage msgHum(CHILD_ID_HUM, V_HUM);
MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
void setup()
  // Initialize library and add callback for incoming messages
  gw.begin(incomingMessage, AUTO, true);
  dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
  // Send the Sketch Version Information to the Gateway
  gw.sendSketchInfo("HumTempRelayMotion", "1.0");
  // REGISTER all sensors to gw (they will be created as child devices)
  gw.present(CHILD_ID_HUM, S_HUM);
  gw.present(CHILD_ID_TEMP, S_TEMP);
  gw.present(CHILD_ID_MOTION, S_MOTION);
  gw.present(CHILD_ID_RELAY, S_LIGHT);
  pinMode(RELAY, OUTPUT);
  digitalWrite(RELAY, gw.loadState(RELAY)?RELAY_OFF:RELAY_ON);
  //Serial.begin(9600);
  timer.setInterval(30000, getMeasure);
  metric = gw.getConfig().isMetric;
void loop()
  // Alway process incoming messages whenever possible
  gw.process();
  timer.run();
  boolean tripped = digitalRead(MOTION_SENSOR_DIGITAL_PIN) == HIGH;
  if (tripped != lastTripped) {
    lastTripped = tripped;
    Serial.print("M: ");
    Serial.println(tripped);
    gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
  boolean tripped2 = digitalRead(MOTION_SENSOR_DIGITAL_PIN2) == HIGH;   //
  if (tripped2 != lastTripped2) {
    lastTripped2 = tripped2;
    Serial.print("M2: ");
    Serial.println(tripped2);
    gw.send(msg.set(tripped2?"1":"0"));  // Send tripped value to gw   //
void incomingMessage(const MyMessage &message) {
  // We only expect one type of message from controller. But we better check anyway.
  if (message.type==V_LIGHT) {
     // Change relay state
     digitalWrite( RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
     // Store state in eeprom
     gw.saveState(message.sensor, message.getBool());
     // Write some debug info
     Serial.print("Incoming change for sensor:");
     Serial.print(message.sensor);
     Serial.print(", New status: ");
     Serial.println(message.getBool());
void getMeasure() {
  delay(dht.getMinimumSamplingPeriod());
  float temperature = dht.getTemperature();
  if (isnan(temperature)) {
      Serial.println("Failed reading temperature from DHT");
  } else if (temperature != lastTemp) {
    lastTemp = temperature;
    if (!metric) {
      temperature = dht.toFahrenheit(temperature);
    gw.send(msgTemp.set(temperature, 1));
    Serial.print("T: ");
    Serial.println(temperature);
  float humidity = dht.getHumidity();
  if (isnan(humidity)) {
      Serial.println("Failed reading humidity from DHT");
  } else if (humidity != lastHum) {
      lastHum = humidity;
      gw.send(msgHum.set(humidity, 1));
      Serial.print("H: ");
      Serial.println(humidity);
ledouble33
Re: 2 capteurs pir+dth11+relais
les dispositifs
fets
Message par fets »
Il faut que tu fasses 2 présentations différentes pour les 2 PIR, avec 2 id différents.
De la même façon, il faut 2 messages différents lors de la notification
+1
ledouble33
fets a écrit :Salut,
Je suis désolé mais j ai appris un peux le c++ mais je maittrise pas super bien
fets
Message par fets »
ledouble33 a écrit :Je suis désolé mais j ai appris un peux le c++ mais je maittrise pas super bien
Alors il faut faire (en ayant au prélable défini CHILD_ID_MOTION2 en début de sketch avec une valeur différente des autres ID) :
déclarations:
MyMessage msg2(CHILD_ID_MOTION2, V_TRIPPED);
présentations:
gw.present(CHILD_ID_MOTION2, S_MOTION);
loop:
gw.send(msg2.set(tripped2?"1":"0")); // Send tripped value to gw //
ça devrait le faire
ledouble33
merci
j ai fais la modification ,les 2 pir s affiche bien mais plus le relais
je comprend pas pourquoi?
#include <SPI.h>
#include <Wire.h>
#include <DHT.h>
#define CHILD_ID_MOTION2 5
#define MOTION2_SENSOR_DIGITAL_PIN 5
MySensor gw;
DHT dht;
SimpleTimer timer;
float lastTemp;
float lastHum;
void setup()
void loop()
  gw.process();
  timer.run();
  boolean tripped2 = digitalRead(MOTION2_SENSOR_DIGITAL_PIN) == HIGH;   //
void getMeasure() {
    if (!metric) {
      lastHum = humidity;
ledouble33
finalement ca fonctionne j ai changer l arduino nano
:D
merci de votre aide
que ca profite a d autre
fets
Message par fets »
Normal, il faut bien débuter un jour :D
ledouble33
Quel est la porté de my sensor avec un nrf24 sans l antenne ?
Il y en a qui ajout un style de condensateur
Vous avez quoi comme capteur mysensor ?
