Problème liaison Edomoticz
Miichael
Message par Miichael »
Je viens de faire une installation domotique pour la 1re fois.
J’ai suivi les vidéos/Tutos des frères poulains sur YouTube.
J’ai donc pris 2 sonoff commandés par tasmota en MQTT. Un Raspberry 4 avec Domoticz, Homebridge et mosquitto installé dessus.
Le MQTT entre l’interface Tasmota et domoticz fonctionne bien. Mais la liaison entre Homebridge et Domoticz ne se fait pas…
Voici mon code dans config :
    "bridge": {
        "name": "Homebridge",
        "username": "DC:A6:32:38:4C:7F",
        "port": 51826,
        "pin": "031-45-154"
    "platforms": [
            "name": "eDomoticz",
            "server": "127.0.0.1",
            "port": "8080",
            "roomid": 2,
            "mqtt": true,
            "ssl": false,
            "dimFix": 0,
            "platform": "eDomoticz"
            "name": "Config",
            "port": 8581,
            "platform": "config"
    "accessories": []
Et la Réponse de HomeBridge :
 [2020-4-26 12:12:08] [eDomoticz] synchronizeAccessories in progress...
[2020-4-26 12:12:08] Homebridge is running on port 51826.
[2020-4-26 12:12:08] [eDomoticz] There was a problem connecting to Domoticz. (HTTP Status code 401)
<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>
[2020-4-26 12:12:08] [eDomoticz] There was an error while getting the MQTT Hardware Device from Domoticz.
Please verify that you have added the MQTT Hardware Device and that the hardware device is enabled.
Si je change mon port en 8741, j’obtiens
 [2020-4-26 12:16:19] [eDomoticz] synchronizeAccessories in progress...
[2020-4-26 12:16:19] Homebridge is running on port 51826.
[2020-4-26 12:16:19] [eDomoticz] There was a problem connecting to Domoticz.
- Error: connect ECONNREFUSED 127.0.0.1:8741
[2020-4-26 12:16:19] [eDomoticz] There was an error while getting the MQTT Hardware Device from Domoticz.
Et si je mets mon port local 1883 :
[2020-4-26 12:20:54] [eDomoticz] There was a problem connecting to Domoticz.
- Error: read ECONNRESET
[2020-4-26 12:20:54] [eDomoticz] There was an error while getting the MQTT Hardware Device from Domoticz.
Je n’ai jamais réussi à les liés, j’ai cherché un peu partout et je n’ai rien trouvé de concret à mon problème…
J’espère que vous pourriez m’aider à résoudre mon problème.
En vous remerciant !!!
Re: Problème liaison Edomoticz
Recherche "Homebridge" sur le forum.
Miichael
Merci de ta réponse.
J'ai donc refait un tour sur le forum et j'ai relu un topic mais il n'y a pas de réponse concrète... (Sujet homebridge).
J'ai donc tenté de modifier le fichier config.json mais j'ai dû faire une mauvaise manipulation et j'ai été obligé de tout réinstaller sur mon raspberry... :cry: :cry:
J'ai toujours le même message sur puty quand je tape "homebridge" :
config.json (/home/pi/.homebridge/config.json) not found
Je ne vais pas le toucher, car je vais devoir tout réinstaller sinon. Mais c'est ce fichier qui faut modifier ?
Merci !
david86
Message par david86 »
Ok pour le message d'erreur quand tu tapes homebridge en commande linux, mais via ton explorateur internet, arrives-tu a aller sur la page homebridge en tapant l'adresse ip de ton raspberry:8581 ? A partir de cette page tu peux modifier ton fichier config.json
l'erreur 401 je l'ai eu, j'ai remplacé 127.0.0.1 (qui vuet dire local en gros) par la vrai adresse ip de mon raspberry (192.168.1......) et ça a marché après.
Es-tu sur que ton broker mqtt est bien installé ?
https://www.youtube.com/watch?v=FsSlgAWtGio
installation de 3:45 à 7:30
test de fonctionnement du broker de 7:30 à 10:30
au déla c'est l'intégration dans domoticz mais c'est pas ton soucis pour le moment.
Raspberry Pi 3, Domoticz, RFXComm, contrôle RTS, contrôle SPOT PISCINE ;-), 2 inter Chacon 1000W, 2 inter CHACON 3000W, AEON Stick ZWAVE, 1 wall plug
1 WEMOS avec capteur pression
Boitier sonde + LED en cours...
Miichael
Merci pour ta réponse.
Oui, je peux aller directement sur Homebridge via l'explorateur.
J'ai suivi la vidéo complète, refait une installe de mosquitto.
De tasmota a Domoticz, cela fonctionne.
Le log de demoticz :
2020-04-27 10:42:48.360 Status: MQTT: Connecting to 192.168.1.48:1883
2020-04-27 10:42:48.560 Status: MQTT: connected to: 192.168.1.48:1883
2020-04-27 10:42:48.761 Status: MQTT: Subscribed
Je vais pour modifier le fichier config.json :
    "bridge": {
        "name": "Homebridge 1BC1",
        "username": "0E:51:C3:2C:1B:C1",
        "port": 51113,
        "pin": "205-74-759"
    "accessories": [],
    "platforms": [
            "name": "Config",
            "port": 8581,
            "server": "192.168.1.48",
            "port": "8080",
            "roomid": 2,
            "mqtt": {
                "host": "192.168.1.48",
                "port": 1883,
                "topic": "domoticz/out",
                "username": "MQTT",
                "password": "*****"
            "ssl": false,
            "dimFix": 0,
Et j'ai toujours mon erreur 401
[2020-4-27 10:58:18] [eDomoticz] synchronizeAccessories in progress...
[2020-4-27 10:58:18] Homebridge is running on port 51113.
[2020-4-27 10:58:18] [eDomoticz] There was a problem connecting to Domoticz. (HTTP Status code 401)
[2020-4-27 10:58:18] [eDomoticz] There was an error while getting the MQTT Hardware Device from Domoticz.
[2020-4-27 10:58:56] [Config] [homebridge-config-ui-x] Failed to check registry.npmjs.org for updates: timeout of 5000ms exceeded
Image de domoticz MQTT en PJ
Il doit y avoir une chose que je loupe, mais quoi...
Merci pour votre aide.
Miichael
Je reviens vers vous !!!!
En cherchant sur les forums anglophones, je me suis rendu compte de mon erreur.
C'est que j'ai mis des identifiants a Domoticz et donc, il ne pouvait pas de connecter.
Quand vous allez dans "configuration" - "Paramètres" de Domoticz, vous avez Sécurité. Et j'ai rempli les cases, pour la sécurité de mon réseau...
Et donc HomeBridge n'arrivait pas à se connecter.
Dans Homebridge, là où il faut renseigner le serveur, il faut aussi mettre les ID de connexion de Domoticz !
J'arrive à me connecter.
Je vous remercie pour votre aide !
Stem_master
Message par Stem_master »
Peux tu indiquer comment tu as renseigner les id domoticz dans homebridge ?
Merci par avance
Mx_Dx
Message par Mx_Dx »
J'ai le même problème mais je n'ai pas reussi a le resoudre. Mais j'ai exactement la meme erreur. Si quelqu'un peu m'aider...
aouzgaga
Message par aouzgaga »
Si cela peut aider, j'ai dû rajouter le 127.0.0.1 en plus de la plage d'ip locale (192.168.0.*).
MicMac
Message par MicMac »
Déterrage de sujet ON.
Bonjour, j'ai le même problème, j'ai déjà essayé plusieurs configuration mais rien n'y fait, quelqu'un peut m'aider ?
Voici le json :
    "name": "Domoticz",
    "server": "HomeBridge:..MDP...@192.168.1.###",
    "port": "7351",
    "roomid": 3,
    "mqtt": {
        "host": "192.168.1.###",
        "port": 1883,
        "username": "Domoticz",
        "password": "..MDP..."
    "ssl": false,
    "dimFix": 0,
    "legacyBlinds": 0,
D'avance merci :D
