Plugin Z4D avec new matériel "passerelle Zigbee SLZB 06"
pipiche
Re: Plugin Z4D avec new matériel "passerelle Zigbee SLZB 06"
Message par pipiche »
qu'est ce que ca donne maintenant ca tourne ?
Car sur le dernier démarrage dixit les logs je ne vois pas de problème
Wiki ici
chat sur Keybase.io
salinois
Message par salinois »
c'est stoppé
oui bizarre le fichier de logs se met pas à jour, alors que dans Domoticz "oui"
2025-01-27 15:44:59.797 Status: ZigbeeSLZB06: ++ Channel : 15
2025-01-27 15:45:19.823 Status: ZigbeeSLZB06: Coordinator backup is available: /home/patrick/domoticz/plugins/Domoticz-Zigbee/Data/Coordinator-03.backup
2025-01-27 15:45:30.723 ZigbeeSLZB06: logging_thread - ended
2025-01-27 15:45:30.738 ZigbeeSLZB06: Logging Thread shutdown
2025-01-27 15:45:30.739 ZigbeeSLZB06: 'ZigpyForwarder_3' is running, it must be shutdown otherwise Domoticz will abort on plugin exit.
2025-01-27 15:45:30.740 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:31.741 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:32.742 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:33.742 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:34.743 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:35.744 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:36.745 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:37.746 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:38.746 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:39.747 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:40.748 ZigbeeSLZB06: Warning: Plugin has 1 Python threads running.
2025-01-27 15:45:40.749 ZigbeeSLZB06: Abandoning wait for Plugin thread shutdown, hang or crash may result.
2025-01-27 15:50:27.131 Error: WebServer:8080 thread seems to have ended unexpectedly (last update 349.000000 seconds ago)
2025-01-27 15:50:41.134 Error: WebServer:8080 thread seems to have ended unexpectedly (last update 363.000000 seconds ago)
2025-01-27 15:50:55.137 Error: WebServer:8080 thread seems to have ended unexpectedly (last update 377.000000 seconds ago)
2025-01-27 15:51:09.141 Error: WebServer:8080 thread seems to have ended unexpectedly (last update 391.000000 seconds ago)
2025-01-27 15:51:23.144 Error: WebServer:8080 thread seems to have ended unexpectedly (last update 405.000000 seconds ago)
pipiche
il me faut les logs domoticz et plugin
Wiki ici
chat sur Keybase.io
pipiche
est-ce que je peu avoir accés à ton systeme ?
ssh ?
contactes moi nen MP
Wiki ici
chat sur Keybase.io
salinois
je te les remets
domoticz.log
(1.71 Mio) Téléchargé 119 fois
PluginZigbee_03_3.log
(452.36 Kio) Téléchargé 138 fois
plus celles que tu as sur le post d'avant.
Je dois m'absenter une heure et demi
a+
salinois
pipiche
il faudrait relancer domoticz, il semble etre dans les choux
Wiki ici
chat sur Keybase.io
salinois
fait
salinois
ahh so
PluginZigbee_03_4.log
(462.52 Kio) Téléchargé 129 fois
c'est mieux, hein
je dois partir , je reviens à toute, pour la suite de la mise en place des devices.
et merci
salinois
Dernière modification par salinois le 27 janv. 2025, 20:04, modifié 1 fois.
salinois
hello,
I am come back
J'ai fait l'appairage d'une LED (LIDL). il y a un peu de latence dans les modifs..
salinois
salinois
et la 2eme
j'aime bien quand ça tombe en marche.
demain, je ferai une récap, car là , j'ai fait ça sur mon Domoticz de test.
merci à tous
Salinois
