[Béta]Plugin Zigate USB + Wifi
ericd
Re: [Béta]Plugin Zigate USB
Message par ericd »
Bravo et courage....
Ericd
ebretteville
Message par ebretteville »
APrès update en version beta:
Version: 3.8742
Build Hash: 6bc9850f
Compile Date: 2017-11-18 08:43:56
dzVents Version: 2.3.0
Voilà mes logs:
 2017-11-23 09:34:34.084 (ZiGate) 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .....
2017-11-23 09:34:34.084 (ZiGate) Received 4 bytes of data:
2017-11-23 09:34:34.084 (ZiGate) 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....
2017-11-23 09:34:34.084 (ZiGate) Received 6 bytes of data:
2017-11-23 09:34:34.084 (ZiGate) 00 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ......
2017-11-23 09:34:34.084 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:34.085 (ZiGate) onMessage called
2017-11-23 09:34:34.085 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:34.086 (ZiGate) onMessage called
2017-11-23 09:34:34.086 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:34.136 (ZiGate) Received 6 bytes of data:
2017-11-23 09:34:34.137 (ZiGate) 00 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ......
2017-11-23 09:34:34.137 (ZiGate) Received 4 bytes of data:
2017-11-23 09:34:34.137 (ZiGate) 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....
2017-11-23 09:34:34.137 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:34.137 (ZiGate) onMessage called
2017-11-23 09:34:34.138 (ZiGate) onMessage called
2017-11-23 09:34:34.138 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:34.188 (ZiGate) Received 3 bytes of data:
2017-11-23 09:34:34.189 (ZiGate) 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ...
2017-11-23 09:34:34.189 (ZiGate) Received 1 bytes of data:
2017-11-23 09:34:34.189 (ZiGate) 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2017-11-23 09:34:34.189 (ZiGate) Received 5 bytes of data:
2017-11-23 09:34:34.189 (ZiGate) 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .....
2017-11-23 09:34:34.189 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:34.189 (ZiGate) onMessage called
2017-11-23 09:34:34.190 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:34.190 (ZiGate) onMessage called
2017-11-23 09:34:34.241 (ZiGate) Received 6 bytes of data:
2017-11-23 09:34:34.241 (ZiGate) 00 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ......
2017-11-23 09:34:34.241 (ZiGate) Received 3 bytes of data:
2017-11-23 09:34:34.241 (ZiGate) 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ...
2017-11-23 09:34:34.241 (ZiGate) Received 5 bytes of data:
2017-11-23 09:34:34.241 (ZiGate) 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .....
2017-11-23 09:34:34.241 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:34.241 (ZiGate) onMessage called
2017-11-23 09:34:34.242 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:34.242 (ZiGate) onMessage called
2017-11-23 09:34:34.254 RFLink: 20;3D;Alecto V4;ID=5678;TEMP=008a;HUM=74;
2017-11-23 09:34:34.262 (RFLink) Temp + Humidity (Extérieur)
2017-11-23 09:34:38.415 (ZiGate) 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....
2017-11-23 09:34:38.415 (ZiGate) Received 5 bytes of data:
2017-11-23 09:34:38.415 (ZiGate) 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .....
2017-11-23 09:34:38.416 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.416 (ZiGate) onMessage called
2017-11-23 09:34:38.417 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.417 (ZiGate) onMessage called
2017-11-23 09:34:38.467 (ZiGate) Received 5 bytes of data:
2017-11-23 09:34:38.467 (ZiGate) 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .....
2017-11-23 09:34:38.468 (ZiGate) Received 1 bytes of data:
2017-11-23 09:34:38.468 (ZiGate) 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2017-11-23 09:34:38.468 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.468 (ZiGate) onMessage called
2017-11-23 09:34:38.469 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.469 (ZiGate) onMessage called
2017-11-23 09:34:38.519 (ZiGate) Received 1 bytes of data:
2017-11-23 09:34:38.519 (ZiGate) 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2017-11-23 09:34:38.520 (ZiGate) Received 6 bytes of data:
2017-11-23 09:34:38.520 (ZiGate) 00 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ......
2017-11-23 09:34:38.520 (ZiGate) Received 5 bytes of data:
2017-11-23 09:34:38.520 (ZiGate) 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .....
2017-11-23 09:34:38.520 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.520 (ZiGate) onMessage called
2017-11-23 09:34:38.521 (ZiGate) onMessage called
2017-11-23 09:34:38.521 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.572 (ZiGate) Received 6 bytes of data:
2017-11-23 09:34:38.572 (ZiGate) 00 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ......
2017-11-23 09:34:38.572 (ZiGate) Received 5 bytes of data:
2017-11-23 09:34:38.572 (ZiGate) 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .....
2017-11-23 09:34:38.572 (ZiGate) Received 4 bytes of data:
2017-11-23 09:34:38.572 (ZiGate) 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....
2017-11-23 09:34:38.572 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.572 (ZiGate) onMessage called
2017-11-23 09:34:38.573 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.573 (ZiGate) onMessage called
2017-11-23 09:34:38.574 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.574 (ZiGate) onMessage called
2017-11-23 09:34:38.624 (ZiGate) Received 4 bytes of data:
2017-11-23 09:34:38.624 (ZiGate) 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....
2017-11-23 09:34:38.625 (ZiGate) 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....
2017-11-23 09:34:38.625 (ZiGate) Received 3 bytes of data:
2017-11-23 09:34:38.625 (ZiGate) 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ...
2017-11-23 09:34:38.625 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.625 (ZiGate) onMessage called
2017-11-23 09:34:38.626 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.626 (ZiGate) onMessage called
2017-11-23 09:34:38.676 (ZiGate) Received 6 bytes of data:
2017-11-23 09:34:38.676 (ZiGate) 00 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ......
2017-11-23 09:34:38.677 (ZiGate) Received 2 bytes of data:
2017-11-23 09:34:38.677 (ZiGate) 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
2017-11-23 09:34:38.677 (ZiGate) Received 1 bytes of data:
2017-11-23 09:34:38.677 (ZiGate) 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2017-11-23 09:34:38.677 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.677 (ZiGate) onMessage called
2017-11-23 09:34:38.678 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.678 (ZiGate) onMessage called
2017-11-23 09:34:38.728 (ZiGate) Received 4 bytes of data:
2017-11-23 09:34:38.729 (ZiGate) 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....
2017-11-23 09:34:38.729 (ZiGate) Received 5 bytes of data:
2017-11-23 09:34:38.729 (ZiGate) 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .....
2017-11-23 09:34:38.729 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.729 (ZiGate) onMessage called
2017-11-23 09:34:38.730 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.730 (ZiGate) onMessage called
2017-11-23 09:34:38.781 (ZiGate) Received 3 bytes of data:
2017-11-23 09:34:38.781 (ZiGate) 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ...
2017-11-23 09:34:38.781 (ZiGate) Received 6 bytes of data:
2017-11-23 09:34:38.781 (ZiGate) 00 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ......
2017-11-23 09:34:38.781 (ZiGate) Received 5 bytes of data:
2017-11-23 09:34:38.781 (ZiGate) 00 00 00 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .....
2017-11-23 09:34:38.781 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.781 (ZiGate) onMessage called
2017-11-23 09:34:38.782 (ZiGate) Calling message handler 'onMessage'.
2017-11-23 09:34:38.782 (ZiGate) onMessage called
Je ne vois rien dans les dispositifs.
lamouette
Message par lamouette »
Rassurez moi, le plugin n'est pas encore proposé à la vente ?
Les plugins que vous avez reçu sont liés au "sponsoring" kickstarter ?
bagnico
Message par bagnico »
lamouette a écrit :Rassurez moi, le plugin n'est pas encore proposé à la vente ?
Les précommandes sont ouvertes : http://zigate.fr/produit/zigate-ttl/ :mrgreen:
bagnico
Merci Zaraki!
Pour que la mise à jour sur le capteur de t° soit effective je suppose qu'il faut que je ré-associe à nouveau ?
zaraki673
Message par zaraki673 »
bagnico a écrit :Merci Zaraki!
De rien :D
oui il faut redeclarer les capteurs, mais si déja associé avant, un appuie court sur le bouton suffira (du moins pour les capteurs de temp).
lamouette
Merci, commandé :mrgreen:
ebretteville
Des champs de configuration sont apparus par exemple hex, a quoi correspond il?!
De même pour Multibloc et Free Can
zaraki673
ebretteville a écrit :Bonjour
:shock:
c est pas moi !! promis :lol: ,
ne configure que les deux USB, c est pareil je vois pas pourquoi il y en a deux ... le plugin du rfplayer ne fait pas se bug lui et y a rien de différent ds la partie config du code ... :(
deennoo
Message par deennoo »
On avance on avance !
J'ai a moitié mis le capteur de presence Xiaomi Aqara dans le plugin, reste maintenant le capteur de luminosité a créer.
Enfin de compte ce capteur il ne revient pas a Zero tout seul ! c'est la gateway qui le faisait revenir, sinon il reste bien ON tout le temps, mais il y a quand meme une tempo entre deux On, reste a voir de combien.
Demain j'essaye de rajouter des inters 230v doubles au plugin
