[Tuto] Programmation hebdomadaire pour chauffage ou interrupteurs
papoo
Re: Programmation hebdomadaire pour chauffage ou interrupteurs
Message par papoo »
DeviceTimersController.js
define(['app', 'timers/factories', 'timers/components'], function (app) {
    app.controller('DeviceTimersController', function ($scope, $routeParams, deviceApi, deviceLightApi, deviceRegularTimersApi, deviceSetpointTimersApi, deviceTimerOptions, deviceTimerConfigUtils, utils) {
        var vm = this;
        var deviceTimers;
        var deleteConfirmationMessage = $.t('Are you sure to delete this timers?\n\nThis action can not be undone...');
        var clearConfirmationMessage = $.t('Are you sure to delete ALL timers?\n\nThis action can not be undone!');
        vm.addTimer = addTimer;
        vm.updateTimer = updateTimer;
        vm.deleteTimer = utils.confirmDecorator(deleteTimer, deleteConfirmationMessage);
        vm.clearTimers = utils.confirmDecorator(clearTimers, clearConfirmationMessage);
        init();
        function init() {
            vm.deviceIdx = $routeParams.id;
            vm.selectedTimerIdx = null;
            deviceApi.getDeviceInfo(vm.deviceIdx).then(function (device) {
                vm.isLoaded = true;
                vm.itemName = device.Name;
                vm.colorSettingsType = device.SubType;
                vm.dimmerType = device.DimmerType;
                vm.isDimmer = device.isDimmer();
                vm.isSelector = device.isSelector();
                vm.isLED = device.isLED();
                vm.isCommandSelectionDisabled = vm.isSelector && device.LevelOffHidden;
                vm.isSetpointTimers = (device.Type === 'Thermostat' && device.SubType == 'SetPoint') || (device.Type === 'Radiator 1');
                vm.levelOptions = [];
                deviceTimers = vm.isSetpointTimers
                    ? deviceSetpointTimersApi
                    : deviceRegularTimersApi;
                if (vm.isSelector) {
                    vm.levelOptions = device.getSelectorLevelOptions();
                if (vm.isLED) {
                    $scope.$watch(function () {
                        return vm.timerSettings.color + vm.timerSettings.level;
                    }, setDeviceColor);
                if (vm.isDimmer) {
                    vm.levelOptions = device.getDimmerLevelOptions(1);
                if (vm.levelOptions.length > 0) {
                    vm.timerSettings.level = vm.levelOptions[0].value;
                refreshTimers();
            vm.typeOptions = deviceTimerOptions.timerTypes;
            vm.timerSettings = deviceTimerConfigUtils.getTimerDefaultConfig();
        function refreshTimers() {
            deviceTimers.getTimers(vm.deviceIdx).then(function (items) {
                vm.timers = items;
        function setDeviceColor() {
            if (!vm.timerSettings.color || !vm.timerSettings.level) {
                return;
            deviceLightApi.setColor(
                vm.deviceIdx,
                vm.timerSettings.color,
        function getTimerConfig() {
            var utils = deviceTimerConfigUtils;
            var config = Object.assign({}, vm.timerSettings);
            if (!utils.isDayScheduleApplicable(config.timertype)) {
                config.days = 0;
            if ([6, 7, 10, 12].includes(config.timertype)) {
                config.days = 0x80;
            if (utils.isOccurrenceApplicable(config.timertype)) {
                config.days = Math.pow(2, config.weekday);
            config = Object.assign({}, config, {
                date: utils.isDateApplicable(config.timertype) ? config.date : undefined,
                mday: utils.isRDaysApplicable(config.timertype) ? config.mday : undefined,
                month: utils.isRMonthsApplicable(config.timertype) ? config.month : undefined,
                occurence: utils.isOccurrenceApplicable(config.timertype) ? config.occurence : undefined,
                weekday: undefined,
                color: vm.isLED ? config.color : undefined,
                tvalue: vm.isSetpointTimers ? config.tvalue : undefined,
                command: vm.isSetpointTimers ? undefined : config.command,
                randomness: vm.isSetpointTimers ? undefined : config.randomness
            var error = deviceTimerConfigUtils.getTimerConfigErrors(config);
            if (error) {
                ShowNotify(error, 2500, true);
                return false;
            var warning = deviceTimerConfigUtils.getTimerConfigWarnings(config);
            if (warning) {
            return config;
        function addTimer() {
            const config = getTimerConfig();
            if (!config) {
                return false;
            deviceTimers
                .addTimer(vm.deviceIdx, config)
                .then(refreshTimers)
                .catch(function () {
                    HideNotify();
                    ShowNotify($.t('Problem adding timer!'), 2500, true);
        function updateTimer(timerIdx) {
            if (!config) {
                return false;
            deviceTimers
                .updateTimer(timerIdx, config)
                    HideNotify();
                    ShowNotify($.t('Problem updating timer!'), 2500, true);
        function deleteTimer(timerIdx) {
            return deviceTimers.deleteTimer(timerIdx)
                    HideNotify();
                    ShowNotify($.t('Problem deleting timer!'), 2500, true);
        function clearTimers() {
            return deviceTimers
                .clearTimers(vm.deviceIdx)
                    HideNotify();
                    ShowNotify($.t('Problem clearing timers!'), 2500, true);
https://pon.fr github
jackslayter
Message par jackslayter »
syrhus
Message par syrhus »
Une toute nouvelle mise à jour a été mise sur github:
- amélioration des performances
- facilité d'intégration (tant que ce n'est pas dans la branche principale de Dz) : moins de code à ajouter dans le fichier DeviceTimersController.js
ATTENTION, désormais le fichier planning.js se met sous www/app/timers et non plus sous le répertoire /js
- correction de certains bugs
Raspberry pi 3B+, Domoticz V4.7900 + beta, Z-WAVE stick Aeon Gen5, RFX 433Mhz
Steph38
Message par Steph38 »
Bonjour je doit etre un peu bete mais cela ne fonctionne pas chez moi malgres tous les conseils. Je suis sur un rpi cela peu influencer?
Steph38
Steph38 a écrit : 09 mars 2019, 19:50 Bonjour je doit etre un peu bete mais cela ne fonctionne pas chez moi malgres tous les conseils. Je suis sur un rpi cela peu influencer?
J'avais oublié de mettre à jours dans cette ligne
define(['app', 'timers/factories', 'timers/components','timers/planning']
barbedusud
Message par barbedusud »
bonjour,
J'ai installé Domoticz sur Windows 8 et cela fonctionne parfaitement.
J'ai essayé le script de programmation mais rien n'apparait, il n'y a aucun changement dans la page de planning.
J'ai parcouru toutes les pages mais je n'ai rien trouvé, aussi je m'interroge : l'ensemble de script fonctionne t-il sous windows ?
Merci d'avance
esspic
Message par esspic »
je viens d'installer ce petit script.
Merci beaucoup, ça semble bien fonctionner.
Cependant, pas de nouvelles du concepteur depuis 2018 ? Est-ce que ce script est toujours maintenu ?
skarab22
Message par skarab22 »
Je viens d'arriver sur le forum grâce à ce super script. C'est vraiment un super développement. J'ai une petite question : quelle est la commande derrière "Tout désactiver".
J'aimerai à l'aide d'un script ou d'un interrupteur pouvoir le passer en mode manuel.
syrhus
Bonjour à tous
j'ai mis à jour le code afin de contourner le bug qu'il y a sur le "clear" des timers.
Celui-ci efface tous les timers de TOUS les timerplans (gestion de profils)
Désormais, cela ne supprimer que les timers du profil (ou timerplan) actif.
Merci à skarab22 de m'avoir remonté ce problème.
Quant à la question du "Tout désactiver", cela conserver tous les timers mais les rend inactifs. C'est une sorte de "standby" qui évite d'avoir à supprimer le programme.
On peut voir sur la 1° colonne du tableau que les timers sont passés en inactif.
Si vous remarquez des bugs, n'hésitez pas à les remonter.
Ce code fonctionne sur tous les environnement, c'est du javascript cependant il y a toujours le problème du cache de l'application contre lequel je me bats avec le concepteur mais il ne veut rien savoir.
J'ai d'ailleurs modifié le fichier de cache pour ne plus avoir ces problèmes.
Mes codes sont disponible sous:
https://github.com/syrhus/domoticz-weekly-planning
Dim33
Message par Dim33 »
bonjour Syrhus,
Compte tenu de tes compétences dans le domaine, as-tu un moyen d’éviter ce problème lié au planning de Domoticz ;
viewtopic.php?f=8&t=9127
NUC sous Ubuntu Server / RFXCom / Domoticz Version: 2020.2
