define(['app', 'timers/factories', 'timers/components'], function (app) {
app.controller('DeviceTimersController', function ($scope, $routeParams, deviceApi, deviceLightApi, deviceRegularTimersApi, deviceSetpointTimersApi, deviceTimerOptions, deviceTimerConfigUtils, utils) {
var vm = this;
var deviceTimers;
var deleteConfirmationMessage = $.t('Are you sure to delete this timers?\n\nThis action can not be undone...');
var clearConfirmationMessage = $.t('Are you sure to delete ALL timers?\n\nThis action can not be undone!');
vm.addTimer = addTimer;
vm.updateTimer = updateTimer;
vm.deleteTimer = utils.confirmDecorator(deleteTimer, deleteConfirmationMessage);
vm.clearTimers = utils.confirmDecorator(clearTimers, clearConfirmationMessage);
init();
function init() {
vm.deviceIdx = $routeParams.id;
vm.selectedTimerIdx = null;
deviceApi.getDeviceInfo(vm.deviceIdx).then(function (device) {
vm.isLoaded = true;
vm.itemName = device.Name;
vm.colorSettingsType = device.SubType;
vm.dimmerType = device.DimmerType;
vm.isDimmer = device.isDimmer();
vm.isSelector = device.isSelector();
vm.isLED = device.isLED();
vm.isCommandSelectionDisabled = vm.isSelector && device.LevelOffHidden;
vm.isSetpointTimers = (device.Type === 'Thermostat' && device.SubType == 'SetPoint') || (device.Type === 'Radiator 1');
vm.levelOptions = [];
deviceTimers = vm.isSetpointTimers
? deviceSetpointTimersApi
: deviceRegularTimersApi;
if (vm.isSelector) {
vm.levelOptions = device.getSelectorLevelOptions();
if (vm.isLED) {
$scope.$watch(function () {
return vm.timerSettings.color + vm.timerSettings.level;
}, setDeviceColor);
if (vm.isDimmer) {
vm.levelOptions = device.getDimmerLevelOptions(1);
if (vm.levelOptions.length > 0) {
vm.timerSettings.level = vm.levelOptions[0].value;
refreshTimers();
vm.typeOptions = deviceTimerOptions.timerTypes;
vm.timerSettings = deviceTimerConfigUtils.getTimerDefaultConfig();
function refreshTimers() {
deviceTimers.getTimers(vm.deviceIdx).then(function (items) {
vm.timers = items;
function setDeviceColor() {
if (!vm.timerSettings.color || !vm.timerSettings.level) {
return;
deviceLightApi.setColor(
vm.deviceIdx,
vm.timerSettings.color,
function getTimerConfig() {
var utils = deviceTimerConfigUtils;
var config = Object.assign({}, vm.timerSettings);
if (!utils.isDayScheduleApplicable(config.timertype)) {
config.days = 0;
if ([6, 7, 10, 12].includes(config.timertype)) {
config.days = 0x80;
if (utils.isOccurrenceApplicable(config.timertype)) {
config.days = Math.pow(2, config.weekday);
config = Object.assign({}, config, {
date: utils.isDateApplicable(config.timertype) ? config.date : undefined,
mday: utils.isRDaysApplicable(config.timertype) ? config.mday : undefined,
month: utils.isRMonthsApplicable(config.timertype) ? config.month : undefined,
occurence: utils.isOccurrenceApplicable(config.timertype) ? config.occurence : undefined,
weekday: undefined,
color: vm.isLED ? config.color : undefined,
tvalue: vm.isSetpointTimers ? config.tvalue : undefined,
command: vm.isSetpointTimers ? undefined : config.command,
randomness: vm.isSetpointTimers ? undefined : config.randomness
var error = deviceTimerConfigUtils.getTimerConfigErrors(config);
if (error) {
ShowNotify(error, 2500, true);
return false;
var warning = deviceTimerConfigUtils.getTimerConfigWarnings(config);
if (warning) {
return config;
function addTimer() {
const config = getTimerConfig();
if (!config) {
return false;
deviceTimers
.addTimer(vm.deviceIdx, config)
.then(refreshTimers)
.catch(function () {
HideNotify();
ShowNotify($.t('Problem adding timer!'), 2500, true);
function updateTimer(timerIdx) {
if (!config) {
return false;
deviceTimers
.updateTimer(timerIdx, config)
HideNotify();
ShowNotify($.t('Problem updating timer!'), 2500, true);
function deleteTimer(timerIdx) {
return deviceTimers.deleteTimer(timerIdx)
HideNotify();
ShowNotify($.t('Problem deleting timer!'), 2500, true);
function clearTimers() {
return deviceTimers
.clearTimers(vm.deviceIdx)
HideNotify();
ShowNotify($.t('Problem clearing timers!'), 2500, true);
