bonjour
l'ip n'a pas changé car j’accède bien à phoscon et tvheadend. J'arrive bien aussi à me connecter via putty.
En local non plus domoticz n'est pas dispo (offline malgres les nonbreux restart du service). mais en locale j'utilise adressPi:8080. quand je fais en locale 127.0.0.1:8080 j'ai rien non plus. (c'est bien ca l'adresse locale ?)
j'ai tenté de creer un log,
j'ai eu ca mais impossible a dire si c'est bien ou pas ... (y a des erreurs mais je ne les comprends pas)
2021-01-31 19:04:07.237 Status: Domoticz V2020.2 (c)2012-2020 GizMoCuz
2021-01-31 19:04:07.238 Status: Build Hash: b63341bc0, Date: 2020-04-26 13:47:55
2021-01-31 19:04:07.238 Status: Startup Path: /home/pi/domoticz/
2021-01-31 19:04:07.263 Sunrise: 08:22:00 SunSet: 18:09:00
2021-01-31 19:04:07.263 Day length: 09:47:00 Sun at south: 13:16:00
2021-01-31 19:04:07.263 Civil twilight start: 07:51:00 Civil twilight end: 18:40:00
2021-01-31 19:04:07.263 Nautical twilight start: 07:16:00 Nautical twilight end: 19:15:00
2021-01-31 19:04:07.263 Astronomical twilight start: 06:42:00 Astronomical twilight end: 19:50:00
2021-01-31 19:04:07.334 Status: PluginSystem: Started, Python version '3.7.3'.
2021-01-31 19:04:07.339 Active notification Subsystems: email (1/13)
2021-01-31 19:04:07.341 Status: WebServer(HTTP) started on address: :: with port 8080
2021-01-31 19:04:07.404 Status: WebServer(SSL) started on address: :: with port 443
2021-01-31 19:04:07.405 Status: Camera: settings (re)loaded
2021-01-31 19:04:07.406 Starting shared server on: :::6144
2021-01-31 19:04:07.406 Status: TCPServer: shared server started...
2021-01-31 19:04:07.407 Status: RxQueue: queue worker started...
2021-01-31 19:04:09.407 Status: RFXCOM: Worker started...
2021-01-31 19:04:09.408 Status: Hardware Monitor: Started
2021-01-31 19:04:09.432 Status: PVOutput (Input): Worker started...
2021-01-31 19:04:09.432 Status: (ONDULEURx) Started.
2021-01-31 19:04:09.432 Status: EnphaseAPI Worker started...
2021-01-31 19:04:09.433 Status: EnOcean: Worker started...
2021-01-31 19:04:09.434 Status: EcoCompteur: Worker started...
2021-01-31 19:04:09.434 Status: (Conbee) Started.
2021-01-31 19:04:09.434 Status: (Clim Mitsubischi) Started.
2021-01-31 19:04:09.434 Status: (linky_production) Started.
2021-01-31 19:04:09.434 Status: NotificationSystem: thread started...
2021-01-31 19:04:09.435 Status: EventSystem: reset all events...
2021-01-31 19:04:09.436 Status: EventSystem: reset all device statuses...
2021-01-31 19:04:09.616 Error: Domoticz(pid:7389, tid:7423('MainWorker')) received fatal signal 6 (Aborted)
2021-01-31 19:04:09.616 Error: siginfo address=0x1cdd, address=0xffffffff
2021-01-31 19:04:09.640 Status: EnOcean: Using serial port: /dev/ttyUSB21
2021-01-31 19:04:09.640 Status: EnOcean Send: 55 00 01 00 05 70 08 38
2021-01-31 19:04:09.640 Status: EnOcean Send: 55 00 01 00 05 70 03 09
2021-01-31 19:04:09.715 Status: EnOcean: 02 (05/01) 00 FF A0 34 80 0A
2021-01-31 19:04:09.715 Status: EnOcean: Transceiver ID_Base: 0xffa03480
2021-01-31 19:04:09.765 Status: PluginSystem: Entering work loop.
2021-01-31 19:04:09.896 Status: (ONDULEURx) Entering work loop.
2021-01-31 19:04:09.896 Status: (ONDULEURx) Initialized version 0.2.3, author 'logread'
2021-01-31 19:04:09.915 Status: EnOcean: 02 (21/00) 00 02 0B 01 00 02 06 03 00 01 9D 40 69 45 4F 01 03 47 41 54 45 57 41 59 43 54 52 4C 00 00 00 00 00
2021-01-31 19:04:09.915 Status: EnOcean: Version_Info, App: 02.0b.01.00, API: 02.06.03.00, ChipID: 01.9d.40.69, ChipVersion: 45.4f.01.03, Description: GATEWAYCTRL
2021-01-31 19:04:12.238 Status: RFXCOM: Using serial port: /dev/ttyUSB11
2021-01-31 19:04:12.270 Error: Thread 12 (Thread 0xafeff220 (LWP 7423)):
2021-01-31 19:04:12.270 Error: #0 __waitpid (options=0, stat_loc=0xafefd2e0, pid=7490) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2021-01-31 19:04:12.271 Error: #1 __waitpid (pid=7490, stat_loc=0xafefd2e0, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2021-01-31 19:04:12.271 Error: #2 0x002db8ec in dumpstack_gdb(bool) ()
2021-01-31 19:04:12.271 Error: #3 0x002dbeb8 in signal_handler(int, siginfo_t*, void*) ()
2021-01-31 19:04:12.271 Error: #4 <signal handler called>
2021-01-31 19:04:12.271 Error: #5 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2021-01-31 19:04:12.271 Error: #6 0xb6987230 in __GI_abort () at abort.c:79
2021-01-31 19:04:12.271 Error: #7 0x0096d02c in __gnu_cxx::__verbose_terminate_handler() ()
2021-01-31 19:04:12.271 Error: #8 0x008d04cc in __cxxabiv1::__terminate(void (*)()) ()
2021-01-31 19:04:12.271 Error: #9 0x008d0540 in std::terminate() ()
2021-01-31 19:04:12.271 Error: #10 0x008daff0 in __cxa_throw ()
2021-01-31 19:04:12.271 Error: #11 0x00909a48 in std::__throw_invalid_argument(char const*) ()
2021-01-31 19:04:12.271 Error: #12 0x0039cd74 in unsigned long long __gnu_cxx::__stoa<unsigned long long, unsigned long long, char, int>(unsigned long long (*)(char const*, char**, int), char const*, char const*, unsigned int*, int) ()
2021-01-31 19:04:12.271 Error: #13 0x0037e4f0 in http::server::CWebServer::GetJSonDevices(Json::Value&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, bool, bool, long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2021-01-31 19:04:12.271 Error: #14 0x0024e2d0 in CEventSystem::UpdateJsonMap(CEventSystem::_tDeviceStatus&, unsigned long long) [clone .constprop.1295] ()
2021-01-31 19:04:12.271 Error: #15 0x00261354 in CEventSystem::GetCurrentStates() ()
2021-01-31 19:04:12.271 Error: #16 0x00261cb4 in CEventSystem::StartEventSystem() ()
2021-01-31 19:04:12.271 Error: #17 0x002aa984 in MainWorker::Do_Work() ()
2021-01-31 19:04:12.271 Error: #18 0x009447ec in execute_native_thread_routine ()
2021-01-31 19:04:12.271 Error: #19 0xb6b94494 in start_thread (arg=0xafeff220) at pthread_create.c:486
2021-01-31 19:04:12.271 Error: #20 0xb6a47578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Raspberry / domoticz / RFXCOM / Conbee II / IPX800v4 / Ecodevice RT2 / enocean / enphase
